Go to Post Cheap is always a good thing, unless you are building a robot. - Francis-134 [more]
Unread 24-09-2013, 17:28
Invictus3593's Avatar
Invictus3593 Invictus3593 is offline
time you like wasting is not wasted
FRC #3593 (Team Invictus)
Invictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really nice
cRIO image 2012
So, we imaged our 8-slot cRIO from 2011 to the v47 image. When we start run our robot, the robot doesn't want to realize there is a solenoid module there, even though it does see the module when imaging. We think that the image for the cRIO is the problem, since we had no problems with the 2012 image that used runtime 11, and in the new image it has runtime 12. So does anybody have a non-2013 version of the image for the 8-slot cRIO? Should just be a .zip pack, right?
Unread 24-09-2013, 18:53
Re: cRIO image 2012
Did you move the solenoid module to the correct slot for the new image? The imaging tool shows you the correct slots.
Unread 24-09-2013, 23:33
Re: cRIO image 2012
Yeah, it's in the right one. We even tried putting it in the old slot just to be sure
We get all green cards in the imaging tool when that starts up
Unread 25-09-2013, 06:19
Re: cRIO image 2012
Has the code been updated to the new module numbering scheme? It should say module 1 or 2, not Slot 8.
Unread 25-09-2013, 12:54
Re: cRIO image 2012
Yeah, we tried using both "Solenoid Module 1" and "Solenoid Module 2". It may just be our cRio:/
We emailed NI to see if they have a previous version of the image with runtime 11 beacuse that's what worked before, then we would just have to use the program written in labview 2011.
Unread 25-09-2013, 13:20
Re: cRIO image 2012
Can you post your code? Is there an error message about the solenoid module, or does it just not work?
Unread 01-10-2013, 08:58
Re: cRIO image 2012
It just doesn't work. We've programmed this bot a million times because it's just a compressor, two solenoids and drive. The only problem is when we re-imaged with the 2013 image.
Before we imaged, it said that it had runtime 11, now it has 12; would that have anything to do with it?
PS: this is not a competition bot, it's a t-shirt cannon for football games
Unread 01-10-2013, 09:36
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
Re: cRIO image 2012
We ran into this exact same issue -- for a t-shirt cannon robot too!
Once we reimaged the 8 slot cRIO with the 2013 tool, it required that we moved the modules to the same configuration as the 4 slot, and it worked for us.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 01-10-2013, 14:17
Re: cRIO image 2012
We had only tried re-imaging with the modules in the old configuration, we'll try the whole process in the new one and see if that works!
