Go to Post The ChiefDelphi forums are more than just a place for people to kill time and engage in some chit chat. - Karthik [more]
Unread 01-10-2013, 10:57
DaboRoss's Avatar
DaboRoss DaboRoss is offline
User.
FRC #4030 (NullPointerException)
DaboRoss is an unknown quantity at this point
Programming on ARM computer
I'm attempting to get the NetBeans plugin for FRC java to work on a chromebook with an ARM processor running Ubuntu. But when I try to load up the plugin on this computer, I'm getting this:
install-platform-specific:
/home/dabo/sunspotfrcsdk/install.xml:43: Could not install platform specific. Unsupported OS: Linux arm
I'd previously been programming on Ubuntu on a computer with an i7, and it worked great, but this computer has a super nice battery life, and I'd like to get it working on an ARM processor as well.
I have a few questions that can probably help me do this:
1. What do these platform specifics do? Is it possible to compile code onto the robot without them?
2. Are these open source? If so, where could the sources be found?
I could probably use them to compile them on this computer, and then manually install them.
3. Has anyone else gotten this working on ARM? If so, could you share your experience?
I'd be grateful if you could help with / answer any of these questions!
~Dabo Ross
Unread 01-10-2013, 17:47
joelg236 joelg236 is online now
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: Programming on ARM computer
If I remember correctly, the plugins depend on libc6 32 bit version. Not sure if that helps you in any way.
All opinions are my own.
Unread 05-10-2013, 23:28
yash101 yash101 is offline
AKA: null
I think it works on my Raspberry Pi. I installed everything using the default way, and netbeans using apt-get
try apt-get install netbeans
then the rest of the instruction on the FRC WPILIB Cookbook. I believe that APT will find the best package, meant for your resources and install that, instead of a general passage. It will also gather the resources.
Unread 12-10-2013, 02:58
DaboRoss's Avatar
User.
NetBeans and programming it works fine, it is just that I can't seem to deploy any code onto the robot from this computer. @yash101, which instructions in particular are you thinking about? I followed the ones that I found but ended with the above mentioned error message, and that seems to stop me from deploying the program.
The plugins are actually working pretty well, I mean the class path works, and I can program with it, it just won't deploy.
~Dabo Ross
