to all you guys who have played a LOT with these motors..
Posted by Anton Abaya at 1/20/2001 1:12 AM EST
Coach on team #419, Rambots, from UMass Boston / BC High and NONE AT THE MOMENT! .we're thinking of doing some tinkering with these motors ourselves but were wondering what other teams have played with... question 1: what is the MAXIMUM speed you think you can attain with these motors with a robot weight of ~130lbs? in ft/sec....given the proper gear ratios and CONTINUOUSLY without heating up the circuit breakers? question 2: is there anything wrong with running the motors at a high gear and at a gear ratio that will output say 14ft/sec, but limiting the maximum speed at 10ft/sec via software? question 3: anyone have experience with running these 1:1 at high gear or low gear? question 4: we want to test our output amperage from that go through our wires especially the ones from our motors, compressor, etc. Someone recommended purchasing an ampmeter that would support a high amperage. Anyone have any ideas where we can purchase one? The CHEAPER the better. thanks guys... -anton ps. it's really hard to make a robot with an extremely small budget with barely any experience, but forums like these and the advice i've gotten has made that possible..thanks guys. |
Re: to all you guys who have played a LOT with these motors.
Posted by Matt Leese at 1/20/2001 4:58 PM EST
Other on team #73, Tigerbolt, from Edison Technical HS and Alstom & Rochester Institute of Technology. In Reply to: to all you guys who have played a LOT with these motors.. Posted by Anton Abaya on 1/20/2001 1:12 AM EST: : we're thinking of doing some tinkering with these motors ourselves but were wondering what other teams have played with... : question 1: what is the MAXIMUM speed you think you can attain with these motors with a robot weight of ~130lbs? in ft/sec....given the proper gear ratios and CONTINUOUSLY without heating up the circuit breakers? I'm not going to guess but it's mostly a factor of the static and kinetic friction provided from the wheels to the carpet. You'd be gearing up from high speed to get there and that's just a bad idea. : question 2: is there anything wrong with running the motors at a high gear and at a gear ratio that will output say 14ft/sec, but limiting the maximum speed at 10ft/sec via software? Well, you lose torque that way. It's more efficient to just gear down the motor and create more torque that way. : question 3: anyone have experience with running these 1:1 at high gear or low gear? Yes, it's a bad idea. You get a fast robot but it's rather hard to control and it does nasty things to the drill motors themselves (killed two of them that way). It also provides a robot with very little torque : question 4: we want to test our output amperage from that go through our wires especially the ones from our motors, compressor, etc. Someone recommended purchasing an ampmeter that would support a high amperage. Anyone have any ideas where we can purchase one? The CHEAPER the better. You can buy an ampmeter at Sear's for one. You may just want to buy a multimeter that can read other things such as resistance and voltage. Just make sure that it supports DC circuits. You may want a clamp on multimeter in order to read the values more easily. I know Sear's sells a clamp on multimeter for about $100. Matt |
| Long list of Thanks/Congrats from 461. | Josh Hambright | Thanks and/or Congrats | 10 | 08-04-2003 12:49 |
| Now it's my turn to say THANK YOU. | archiver | 2000 | 0 | 23-06-2002 22:56 |
| Looking for practice motors & extra tape drive parts? | archiver | 2000 | 1 | 23-06-2002 22:54 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
| Drill Motors | TF8 | Motors | 19 | 12-12-2001 13:13 |
