Go to Post If duct tape isn't the answer, you're not asking the right question. - Morgoth [more]
Unread 23-06-2002, 23:33
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Dismantle Solenoid valve?
Posted by Josh Vetter at 1/24/2001 1:52 PM EST
Student on team #548, Robostangs, from Northville High School and BOSCH.
I was working on a mechanism to grab onto the rail of the goals, or the stretcher, and had a question. Does anyone know if we are allowed to dismantle the solenoid valve included in the pneumatic kit? I want to use the switching device from the valve to perform a different function on the goal-grabbing arm.
Thanks in advance for the help.
Josh Vetter
Unread 23-06-2002, 23:34
#0047 (ChiefDelphi)
nope, sorry
Posted by Jason Rudolph at 1/24/2001 6:38 PM EST
Other on team #459, Rampage, from University of Florida/Eastside High School and .
In Reply to: Dismantle Solenoid valve?
Posted by Josh Vetter on 1/24/2001 1:52 PM EST:
Well, I'd have to say no. Rule M15 in the manual says that "pneumatic components in the kit may not be modified except as follows:" and after that, it does NOT say you may modify the solenoids. The only exception being that you can modify the wiring so that it will interface with the control system.
Hope this helps,
Jason
#0047 (ChiefDelphi)
Re: nope, sorry
Posted by Josh Vetter at 1/24/2001 11:15 PM EST
In Reply to: nope, sorry
Posted by Jason Rudolph on 1/24/2001 6:38 PM EST:
Not the answer I was hoping for, but thanks anyways.
Josh
: Well, I'd have to say no. Rule M15 in the manual says that "pneumatic components in the kit may not be modified except as follows:" and after that, it does NOT say you may modify the solenoids. The only exception being that you can modify the wiring so that it will interface with the control system.
: Hope this helps,
: Jason
[IMG] code is Off
multiple cyclinders from one double solenoid Ed Crammond Pneumatics 1 07-02-2003 18:49
Will trade for double solenoid valve archiver 2001 2 24-06-2002 00:33
Solenoids archiver 2001 9 23-06-2002 23:47
Does anyone have extra solenoid valves????? Elgin Clock Pneumatics 5 18-02-2002 12:43
Single Solenoid Valve SMC Chubtoad Technical Discussion 3 20-01-2002 15:16
