Go to Post Regardless of the next course of action, getting steamed and angry will benefit nobody. And coming from me, that has to mean something. - Lil' Lavery [more]
Unread 10-12-2013, 13:35
Silver's Avatar
Silver Silver is offline
Rookie
AKA: Digby Baker-Porazinski
FRC #5236 (Man O' War)
Team Role: Tactician
Silver will become famous soon enough
Exclamation Where to mount the battery?
Hey all. Digby Baker-Porazinski from team 5236. This is my (our) first post in CD, so everything I say will probably be in some way some sort of taboo.
This probably isn't even in the right section.
Anyway.
This is our first robot of our first year of competing. Design is coming along smoothely, but we've hit our first roadblock: where to mount the battery. We agreed it should be low to keep the center of gravity low (the thing's 14 pounds) and situated in the rear to counterweigh the game mechanism, whatever that may be. But the battery is large and cumbersome, and we're having trouble deciding where to safely and efficiently place it.
That being said, any tips or examples of where you've put your battery in previous years would be much appreciated.
Thanks from Man o' War, team 5236, Cambridge, NY.
Unread 10-12-2013, 13:43
wmarshall11 wmarshall11 is offline
FRC #2399
wmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to beholdwmarshall11 is a splendid one to behold
Re: Where to mount the battery?
Exactly what are you designing for? The FRC build season doesn't start until Kickoff (first Saturday of January), so I assume a preseason warmup bot?
Rule of thumb: Low and to the center, with a container made to prevent the battery from sliding around your robot. For 11, this often means bent 16GA Aluminum, but Beta used 8020 and polycarb to build their battery box. Doesn't really matter as long as it doesn't slide around and doesn't fall off.
Unread 10-12-2013, 13:47
Chris is me's Avatar
AKA: Pinecone
I really don't want to come across as attacking in your first post - I'm just trying to help. But... the main difficulty I think you guys are going to run into is that it's against the rules to start robot design before the build season starts. Besides that, we aren't even sure what size the robots will be yet, which game piece we're using, how we will interact with them, if the field will have any obstacles, etc. I'm not saying it's useless to be thinking about this stuff before Kickoff, but just know that you can't get a jump ahead of anyone by doing "pre-design" or pre-building.
Lots of teams do CAD before the season, in the form of design exercises or practice, including our team. But using any design made before the season starts without changing it is illegal. It's okay to come up with an idea for a drive base and then CAD it, but you can't use that design when the season starts without changing it in some way. On 2791 we usually come up with a concept, then change details once the game comes out (e.g. the size of the frame, exact gearbox layout, etc).
As for a good place for the battery, you want it as low as you can and in a place that you can reasonably get to. It is more important that the main breaker be easy to access than it is for the battery to be, but you still don't want students to have trouble changing it fairly quickly. Stowing the battery vertically in some sort of custom box is a good way to save on space and to make removal easy. Put it off to one side if you have a heavy manipulator on the other side, otherwise try to bring it a little closer to the center.
We don't usually decide exactly where the battery goes before we have an idea of where our manipulator is going to be. We don't want to put it somewhere, and then make students have to reach in / out / around a bunch of parts just to get a hold of it.
Unread 10-12-2013, 13:51
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
The other important thing to keep in mind is that you will be changing the battery every match. The battery needs to easily replaced in the pits.
One option from AndyMark:
http://www.andymark.com/product-p/am-0477.htm
our demo bot just has four blocks screwed to the belly pan and a Velcro strap (battery should not fall out if robot is tipped). Also, be careful of sharp metal brackets which might crack the battery during a robot collision.
Unread 10-12-2013, 14:35
DonRotolo's Avatar
Back to humble
FRC #0832
Welcome to CD. You made a good choice by asking here, since we love to help. And I am sure you understand that using anyhting designed before the season starts is against the rules. Sorry.
For the battery:
Low is good. Protected is good too.
Accessible is critical. You change batteries very often. But make sure no matter what it won't come out (including upside down robots...)
Make absolutely positively certain that the battery terminals cannot touch any ANY metal robot parts. If it does, "Flash, Bang, Send for Help" is sure to happen.
The wires from the battery, through the main circult breaker, to the power distribution board, should all be as short as possible. These wires are heavy, and you do lose power in them, so shorter is better. This means, location should consider other parts.
The orientation of the battery in the robot is NOT important - flat, upright, even upside down are all OK. (Upright for charging though).
Last, if you have a spare week or three, search "Battery" on Chief Delphi and read all the posts from the last decade. You will truly be an expert if you do that.
Good luck in the season, and post often.
Unread 10-12-2013, 15:10
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
However you decide to mount it, make sure you use foam. It will reduce the vibrations that the battery experiences. You don't want the internal plates touching each other (or any of the other bad things that can happen to a battery). Strap in or otherwise contain your battery as well. Your robot will wind up in an orientation you don't expect.
Battery orientation (flat or standing up) doesn't matter as long as it's not upside down.
Otherwise, what everyone else said applies. Low, contributing to a balanced COG, short wires that don't get pinched and mounted in a way that makes it easy to change batteries quickly.
I recommend using 90º aluminum angle to make your battery mount. It's the perfect shape, strong, light and easy to interface with your other structure.
Here's the battery mount from our 2012 robot. It uses angle on 3 sides with a strap and foam to contain the battery. It tipped over on the field several times without issue.
Unread 10-12-2013, 15:46
yash101 yash101 is offline
AKA: null
SECURE THE BATTERY! You don't want the battery to break and leak acid all over your bionic machine!
Unread 10-12-2013, 16:19
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
A picture is worth a thousand words... Can you post a proposed design picture? Are you 4 wheel drive? 6? This will weigh ( ) in on your placement of the battery as well.
In addition to the posts above, I have some additional considerations. Please also remember this is some general guidance and is not the solution.
You do not necessarily want your CG (Center of Gravity) in the center of your robot, as this is not ideal for a 6wd robot or a 4 wheel drive "narrow" chassis. In the case of a 6WD robot, placing your CG on the rear half may be beneficial in your design, as it is really just a 4wd wide chassis with pair of "extra wheels" up front (NOTE: This is an oversimplification).
For a narrow 4WD, placing the CG towards the rear wheels and adding something like an omni wheel on the front will allow you to rotate the robot easier, as a 4WD narrow tank-style/differential drive bot is difficult to turn due to scrub force.
Unread 10-12-2013, 16:35
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Expanding on the above post about how drive choice relates to battery placement, if you chose to do mecanum (which I don't necessarily recommend as a rookie) CG (and therefore battery placement) becomes much more critical. All in all though, if you are a rookie team with no ridiculous manufacturing resources and little experience, I would just go with the kit chassis, a plywood bellypan and the 3-pieces-of-angle + velcro strap battery holder mentioned earlier.
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
Unread 11-12-2013, 13:26
Silver's Avatar
Rookie
Thank all of you for your input.
WMarshall11: We're just troubleshooting. Nothing is in legitimate design or construction yet, we just saw the weight of the battery online and decided to try and tackle the issue before it arises. I appreciate the help.
Chris is me: I appreciate the info. Worry not, there's no official CAD designing going on yet, we just downloaded a 6-wheel STEP file to examine.
gpetilli: Thanks for the link. We're thinking aluminum with slots, where we'll implement velcro straps. We hadn't taken sharp objects fully into consideration, so that's a good wake-up call.
jman4747: Thanks for the alternate options. Depending on what happens come Kickoff day, we may well need a plan B.
Yash101: Wow. That was very helpful information. Sadly, I doubt we'll get a functioning electrical team going, considering that our team consists mainly of 5 POE students, but it's a useful idea. The link was also very helpful.
Ice.berg: Thank you for your input. We had been considering what sort of fastener/strap we could use, and the different material examples are helpful.
DonRotolo: Again, nothing's really being designed, but I appreciate the heads-up. Thank you for the info, it helps more than you know.
cgmv123: Thanks. Your design seems cost effective and deceptively simple. I also appreciate the visual provided by your photo.
Stinglikeabee: That's very helpful. Our design will likely be 6 wheel, omnis in front and back.
MetalJacket: Sounds good. Definitely not Mecanum, we're nowhere near ready for that. We're thinking 6 wheel, omnis in front and back.
Again, thanks to everyone for your support.
Unread 11-12-2013, 13:39
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
One option you could look at is using the eStop Robotics Battery Base product. Many teams use it and I've never heard of a team losing a battery during a match while using it - https://www.estoprobotics.com/estore...d&productId=10
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 11-12-2013, 14:06
raptaconehs raptaconehs is offline
FRC #3200
raptaconehs will become famous soon enoughraptaconehs will become famous soon enough
Mount the battery underneath the robot. It is pretty fun to deal with.
/sarcasm
Unread 11-12-2013, 14:26
DonRotolo's Avatar
Back to humble
FRC #0832
Actually, even upside down is perfectly fine. Just do not charge it upside down, because of the overpressure vents on top. During use the battery won't need to vent making orientation irrelevant
/sarcasm
I have seen several robots with the battery mounted right to the bottom center of the robot. To change the battery, they just tip the robot on its side, exposng the battery mount.
Unread 19-12-2013, 22:39
vanjan14's Avatar
vanjan14 vanjan14 is offline
2977 Alum/171 Mentor
AKA: Jansen
FRC #0171 (Cheese Curd Herd)
vanjan14 is an unknown quantity at this point
My team has used these for the past few years and have never had a problem with them! The plastic bracket slips into grooves at the top of the battery and holds it very securely. The only thing I would suggest is making sure you have enough clearance to get your hands around the battery to secure the velcro.
Unread 11-12-2013, 15:57
ErvinI ErvinI is offline
AKA: Ervin Ibadula
FRC #0865 (Warp7)
ErvinI is just really niceErvinI is just really niceErvinI is just really niceErvinI is just really niceErvinI is just really nice
Sorry to be a bit off-topic, but why go for this configuration? You'll have very little scrub preventing you to turn, therefore making the robot very hard to drive. Why not just go with the standard kitbot, 6-wheel, dropped centre?
As for the battery mounting, just remember that your battery can be used as a form of "ballast" to move your CoG to somewhere else. Other than that, as long as you can securely mount the battery (using tools such as the Battery Base Mount linked earlier from Andymark) and can access it easily, your battery should be fine as long as it is properly maintained.
P.S. While we're talking about batteries, zip tie the leads. They're the next most likely thing to come lose.
