Current reading of motor controllers
I am currently working on a project my team were i want to have a box that has a power conector to a battery and a connector out to a motor. Im planning to let the build team use it, but I was wondering if there was a way to record amp draw so we could troubleshoot prototypes. Any suggestions?
Re: Current reading of motor controllers
You can use a current/voltage sensing breakout circuit to monitor power draw using analog inputs in your robot control system.
Here's a PCB capable of measuring up to 180 Amps (more than CIM stall current): AttoPilot Voltage and Current Sense Breakout - 180A The current measurement is made across a very low resistance shunt (0.25 milliOhm). Voltage measurement uses a 16KOhm voltage divider. Per 2013 Robot Rules (R54), this breakout circuit should be competition legal: "Custom high impedance voltage monitoring or low impedance current monitoring circuitry connected to the ROBOT’S electrical system is acceptable, if the effect on the ROBOT outputs is inconsequential." |
Thanks a lot, looking for something like this!
You can also get something like this: http://www.radioshack.com/product/in...ductId=4439164
Simply clamp it around the wire to measure the current through the wire. It works equally well for motor current as it does for entire robot current! |
If you use Jaguars, I believe you should be able to read current draw if run in a CAN configuration.
We will be using a jag but were planning to use a micro controller and we dont plan to use can. (Arduino does not suport)
#7
Even if you don't use CAN for drive software, you could use it for diagnostics using bcd-comm on a PC or Mac via a USB-RS232 adapter. |
#8
I know lots of teams don't like Jaguars, and there are lots of valid reasons not to, but it does provide some very nice features. I am disappointed that the CAN version of the Talon does not appear to be available for 2014. We are looking forward for a more robust CAN based speed controller in 2015. |
