File I/O Error
Our team has begun working with image processing and camera tracking, so I'm hoping this is something simple that I missed.
I deployed the 2013 Vision Sample Project to the robot, and when I run Autonomous on the robot I get an error in the netbeans console. It repeats this error in the console until I disable the robot: Code:
[cRIO] edu.wpi.first.wpilibj.image.NIVisionException: File I/O error. [cRIO] at edu.wpi.first.wpilibj.image.NIVision.assertCleanStatus(NIVision.java:1076) [cRIO] at edu.wpi.first.wpilibj.image.NIVision.readFile(NIVision.java:1204) [cRIO] at edu.wpi.first.wpilibj.image.RGBImage.<init>(RGBImage.java:33) [cRIO] at edu.wpi.first.wpilibj.templates.VisionSampleProject2013.autonomous(VisionSampleProject2013.java:85) [cRIO] at edu.wpi.first.wpilibj.SimpleRobot.startCompetition(SimpleRobot.java:130) [cRIO] at edu.wpi.first.wpilibj.RobotBase.startApp(RobotBase.java:169) [cRIO] in virtual method #10 of javax.microedition.midlet.MIDlet(bci=17) [cRIO] at javax.microedition.midlet.MIDletTunnelImpl.callStartApp(64) [cRIO] at com.sun.squawk.imp.MIDletMainWrapper.main(110) [cRIO] in virtual method #95 of com.sun.squawk.Klass(bci=25) [cRIO] at com.sun.squawk.Isolate.run(1506) [cRIO] at java.lang.Thread.run(231) [cRIO] in virtual method #47 of com.sun.squawk.VMThread(bci=42) [cRIO] in static method #3 of com.sun.squawk.VM(bci=6) |
File I/O Error
If you go to 10.xx.yy.11 in an internet browser and log in with Username: FRC password:FRC are you able to see the image?
If that's working try using an FTP client (chrome has one built in) to go to ftp://10.xx.yy.2 and see if the images from you camera are saved there. Last edited by nickmcski : 20-12-2013 at 11:51. |
Re: File I/O Error
[cRIO] at edu.wpi.first.wpilibj.templates.VisionSampleProject2013.autonomous(VisionSampleProject2013.java:85) Code:
//thresholdImage.write("/threshold.bmp");
Have you read the vision processing tutorial? http://wpilib.screenstepslive.com/s/3120/m/8731 |
Re: File I/O Error
Thanks for the help guys! I guess I never thought of the fact that I might have to upload the test image... Thanks for putting me on the right track
