Thread Tools |
Rating:
Display Modes |
pic: 971 Friction Clutch Transmission Insides
Re: pic: 971 Friction Clutch Transmission Insides
This is a really cool approach to take for shifting. What method are you using to transmit force from the cylinder to the clutch mechanism? Roll pin maybe?
Neat!
It looks like with a drum on each second stage gear, that you would need air pressure to engage either gear set, regardless if it is low or high gear, is that correct? Seems like a big plus to that is you can shut off your air pressure after a match and the robot would roll freely with no motors engaged. Based on the results of this off season project, do you see enough benefits to use this approach (instead of dog shifting) if the game requires a two speed drivetrain this year? |
-Travis |
![]() This is really cool, and a unique/very-untraditional way of shifting in FRC |
I hope that this doesn't get lost in the game hint chatter. This really is a huge technological leap, and a great experiment, similar to how a ball shifter was a few years ago. It's just a pity it took 3 weeks to machine. If it didn't, I'm sure 971 would be rocking it next year. I have to hand it to Travis, Austin, Brian, and co for pulling off such a innovative, different and cool idea. Last edited by DampRobot : 22-12-2013 at 01:56. |
#7
I don't understand this viewpoint. Yes, it's cool, but it feels like a solution in search of a problem.
I'm getting nightmare flashbacks to last season... |
#8
They had a clear problem they wanted to solve. An effectively utilized autoshift function with properly picked low/high ratios could potentially shave seconds off each match (4-10 maybe?). This time saved isn't huge, but could amount to a 5-15% increase in scoring each season. Both the dog and ball shifter do not shift instantly, and neither does this clutch method.However the clutch method does shift faster than the previous two, and with a smoother engagement; this better blends with their goal of smooth autoshifting. You can debate whether or not their overall goal is valid or cost effective, but please don't say that it's a solution in search of a problem. Valid analysis and engineering went into this, and it wasn't created for the sake of coolness. |
#9
I wonder, though, if time wouldn't be better spent on low-hanging fruit -- some mentors and I made a lively discussion of this a few months ago when talking about how 1678 could improve our competitiveness. I know 971's bots always have high score ceilings, but often fail to execute to full potential. Would not it be more efficient to ensure basic functionality in each match, as opposed to some fantastic and some mediocre matches, rather than build a smoother autoshifter? (This isn't to say that both of these improvements couldn't happen simultaneously, of course.) Perhaps someone from 971 could chime in here. My mistake. I usually take just this approach. |
#10
), but you can't make these assumptions without any understanding of team structure, goals, etc. I just spent the last 5 hours at 971's shop, I can assure you that developing a friction clutch transmission is certainly NOT the only thing 971 is doing this off-season. Arguably, they've made larger strides this fall than we have.You know what happens when you assume... -Mike |
#11
This was one of several off-season projects, one of the others being a 3rd robot, HP-load only for Ultimate Ascent that we ran at Madtown. That was designed and built almost entirely by freshman and sophomores, with some help from the upperclassmen. The friction clutch is a lot cooler, and I don't know of anyone else in FRC who has tried to make one as a replacement for the dog shifter, so we thought it would be more interesting to CD. Last edited by Nuttyman54 : 22-12-2013 at 02:17. |
#12
It is. Could we get a picture of both halves assembled together?
#13
Try http://www.chiefdelphi.com/media/photos/39233?
This is the closest we have of what you are asking. You can see the large gear and steel drum that is in this picture, and then the opposing steel drum and smaller gear. Unfortunately all of the inner workings get hidden once you assemble it. -Travis |
#14
Pretty cool, I've been thinking about how to implement a clutch transmission for a few months now. Pretty awesome to see. Nice job!
#15
...but it is EXTREMELY cool. If you are unsure as to the exact purpose of someone's particular project (one that they've more than likely poured a tremendous amount of blood, sweat, tears and money into)- there are a number of different ways to approach that viewpoint that will not cutdown someone else's hard effort. Possibly begin a dialogue centering around why shortening shifting time is important to 971... Also keep in mind that you do not necessarily need to optimize-for-efficiency every single action your team takes. Sometimes doing something the hard way, or doing something new, or even something for the sake of coolness can be a great exercise in teamwork and inspiration... Travis, Austin and co., a job very well done. This is a really cool little clutch. Are you guys feeling good about trying to implement it this upcoming season? (Assuming shifting makes sense for the game). -Brando |
