Go to Post For those of us in the north, a water game turns into an ice game, which becomes Lunacy. And I don't think any of us want that. - Kimmeh [more]
Unread 29-12-2013, 03:13
kelsey.m kelsey.m is offline
FRC 4928
FRC #3562 (Arabian Knights)
kelsey.m is an unknown quantity at this point
Joystick refnum name
We added another joystick by copying and pasting then we tried to name them each one to joystick 1 & joystick 2.
For joystick 1 for the get button we changed its refnum name to joystick 1 and then for joystick 2 we changed its refnum name to joystick 2 but when we recheck it we found the refnum name for joystick 1 changed itself to joystick 2 right after we changed the name for joystick 2's refnum name.
We're assuming its because we copied and pasted, can someone explain a fix? Thanks!
6358 Buhl High School
3562 4H LiveWire Robotics
4928 Arabian Knights
3456 LiveWire
Unread 29-12-2013, 10:42
Re: Joystick refnum name
It sounds like you opened the Joystick Refnum Get function and changed the default refnum name inside it. Don't do that. Unless you have a very special and very important reason to make changes to the library's VIs, leave their contents alone.
Instead, just wire a constant string to the refnum name input of the VI, and change the string to be whatever name you want it to be.
