Oops! Google Chrome could not connect to www.usfirst.org
This is the 2ed day http://www.usfirst.org is not working, I recive this massege
You can not view this page |
Re: Oops! Google Chrome could not connect to www.usfirst.org
Works fine in Chrome for me.
Works fine for me too.
Works fine for me as well; I've accessed a few times over the past few days.
Is it possible that your organization's firewall has blocked access? You may wish to check with your IT experts/providers. |
Interesting I've accessed 9 years without any problem
try typing "https://" before the "www.usfirst.org". Whenever chrome does that to me that's usually a fix.
If you can't get access to the documents I'm sure somebody would be happy to send them to you via google drive or some alternative. Just PM me if you need to! Also, seeing as you are from Israel, if it is some sort of region block you can install the chrome extension "Media Hint" which removes region blocks like that on things such as netflix, hulu plus, etc. Not 100% sure if it would work in this situation but I don't see why it wouldn't. Last edited by Mason987 : 03-01-2014 at 18:21. |
#7
I cannot connect to usfirst.org
also with Explorer I am from Israel I still recive You can not view this page |
#9
Works for me, and I'm from Israel too...
#10
go to a command prompt and run "nslookup www.usfirst.org" and post the results.
#11
usfirst.org nslookup results
This page presents the DNS response we got. If you recently made changes to your DNS setup, those results may not be accurate because of the propagation time (DNS results are cached by Name Servers). Domain or Host name Query type Server |
#12
Try going to http://50.203.193.66 |
#13
Have you tried turning your computer on?
