Self pass over the truss
The manual states:
Our team will be submitting a question to Q&A when it goes online, and will be hoping for a final answer from FIRST. Any thoughts? Last edited by GaryVoshol : 04-01-2014 at 14:32. Reason: Cleaned up by removing symbol characters |
Re: Self pass over the truss
"by a ROBOT’S ALLIANCE partner"
Not by the robot itself. |
This seems pretty cut and dry, don't think you can't pass to yourself. Since you are not your own partner.
I guess you could speculate that the GDC intended to make sure you are catching something thrown by your alliance, not the other alliance. It will be interesting to hear what the GDC has to say - it is worth asking.
This is a pretty common question.. Glad it was sorted out soon and without any issues.... It's been asked about 10 times in the last few minutes here at our meet.
exactly
#7
But wouldn't this always be no since the other alliance cannot catch the ball, since it would count as possession and thus be a technical foul?
#8
Closing up loopholes?
#9
good point - not sure
#10
No matter whether the opponent can catch the ball, you can always catch the ball, since you can always possess it. This debate is about whether the catch gains points, and the rules made it clear that a catch only gains points if its by the partner.
So yes, you can catch your own pass but you wouldn't get catch points. |
#11
You wouldn't even have time to throw it up and make it to the other side to catch it.
#12
There are going to be some pretty fast robots out there. I'm pretty certain some of them could do it pretty handily, particularly if they shoot on the move.
#13
The truss is only 1 foot wide, so if you stood almost below it and threw it in a shape like a steep parabola, you would only have to move a foot or two to catch it. |
#14
if you take the size of the robots into consideration you may not even have to move at all because the bot could be long enough to just sit under the truss.
#15
Well you'd probably have to move closer to 5. 2 feet for ball, 1 for truss, then another 2 for the ball as it falls on the other side.
