Team 2619 - Install Problems
Hello everyone!
I am having a very important and very annoying problem. On my laptop (with a Windows 7 64-bit operating system) I cannot, even after installing all of the updates, get the [FIRST] button at the top to appear. I have tried uninstalling and re-installing twice now. I know that the packages should be working, because I installed the packages on another teammate's laptop, and it worked just fine. Any and all help would be greatly appreciated! Thanks, Travis Last edited by Travis_Team2619 : 05-01-2014 at 09:38. |
Re: Team 2619 - Install Problems
Thanks! Travis |
My problem has been solved by my Lead Mentor's son has fixed it. I am grateful for you helping!
Travis |
If you don't mind me asking, how was he able to fix the toolbar not showing up? I'm currently having the same problem.
The FIRST button in the toolbar ribbon appears after installing the WPILib 2014 C++ update (aka Workbench update) available from http://first.wpi.edu/FRC/c/update/Release/.
Make sure to: 1. Close WB before running the installer/update 2. Ensure the Wind River Registry is no longer running (check the available icons in the Windows system tray and ensure the Wind River Registry is set to appear.) 3. Then run the update. |
#7
I have tried installing the workbench update after installing Windriver and making sure that the registry is not running and the FIRST toolbar is not appearing. I have all of the other files such as the WPILib files and the vision examples from this year but the FIRST Toolbar is not appearing.
#8
1) Open the [Start] menu, right click on [Computer], and choose [Properties] (at the bottom of the drop down list) 2) Click on [Advanced system settings] on the left (if you are prompted to enter your administrative password, do so now) 3) Click on [Environment Variables...] 4) Scroll down under the section labeled "System variables" until you see [PATH] under the Variable heading. 5) If [PATH] is not there, you need to click on [New...] 1. Set the Variable Name as PATH, and set the Variable Value as the value shown at the bottom of this post. 6) If [PATH] is there, then you need to click on [PATH] and then [Edit...]. 1. Add a semicolon [;] to the end of what you have in the Variable Value, and paste the value at the bottom of this post to the end of what you already have in the Variable value field. 7) Click Ok until you are back to the [System] screen, then press the X. 8) Run the Updater again (the last thing to do after the 1 or 2 discs). If the text doesn't zip by in 5 seconds, you are good. If it does, continue asking for help on ChiefDelphi. Variable value is all of the following (until the return): %SystemRoot%\system32;%SystemRoot%;%SystemRoot%\Sy stem32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShel l\v1.0\;C:\Program Files\Java\jdk1.6.0_27\bin;C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin\;C:\Program Files\IVI Foundation\VISA\Win64\Bin\;C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin; [*NOTE* I found out how to do this from a previous team member who is now in college. I could maybe ask him for some more help, but it isn't guaranteed.] Last edited by Travis_Team2619 : 08-01-2014 at 00:43. |
