Thread Tools |
Rating:
Display Modes |
Using an air cannon to launch the balls - Arial Assist
What are your thoughts on this?
Re: Using an air cannon to launch the balls - Arial Assist
People try this every year, and every year it's not particularly feasible.
Trust me it dosent work! My team tried it the year before I joined for rebound rumble. We just sat there! So I would highly suggest against it.
In 2008, 1771 had a vacuum system with 3 pistons inside. Suck ball up, then punch it. Air then cannon. It worked for them.
You don't really have the space to mount such a big mechanism. Also, air compressors aren't the most notably fast things in the world, so you'd have to precharge the tanks and continuously have the compressor running, draining your battery. Also, that would be awefully loud! Other than that, I can see the ball moving at 100mph and tearing the field down. This would also be a safety hazard!
Your cannon barrel bore diameter would need to be about two feet to accept the ball -- that is about 450 square inch cross-section area. Robot rule <R82> limits working air pressure to 60 pounds per square inch. The ball weighs about 2.75 pounds.
The numbers do not appear favorable for launch. |
#7
27,000 lbf would probably be enough to move a big-rig! I wonder what would happen to the ball! Just remember: The compressor is a decent-sized motor in charge of storing a ton of energy as compressed gas. Over time, this power builds up until you have stored, for example, 100 watts of energy which you release it within a second! I think that would be: 100w*60s*60m = 360,000 watts per hour are delivered! THAT IS DANGEROUS! |
#8
You are correct in saying that the compressor stores energy in the form of compressed gas, but it isn't stored as power. Power is a measurement of energy transferred per unit of time. One Watt is equal to one Joule of energy per second. As the compressor operates, it converts electrical potential energy into mechanical energy (by compressing air) and heat. If It does this at 12 volts and 15 Amps, It would be running at 12*15, or 180 watts. If it runs for 1 hour, It converts 180 Watt-hours of energy, or 180 * 3600 Joules. Not all of that is stored, however, since a lot of it is lost as heat while the motor is running. Still, even a fraction 648kJ could be quite lethal if it is released carelessly. |
#9
and just for the sake of lols, I have Copioli opened in another tab and someone's singing the Friday Song ![]() |
#10
The nylon bag around the ball will make sealing against your air cannon aperture quite difficult. Personally I would not try it.
#11
-Dick Ledford |
#12
one can imagine that if there were a fixed air gap around the ball it would be difficult to launch and that a zero air gap (a good seal) is ideal - so how does having that nylon bag compromise the seal, how much air escapes without doing any work? |
