Go to Post Drive yourself, ride Amtrak or Greyhound bus, or bend space-time to the point of singularity and you'll just poof into existence in Atlanta. - artdutra04 [more]
Unread 06-01-2014, 20:06
joshwood joshwood is offline
FRC #3756 (RamFerno)
joshwood is an unknown quantity at this point
Question Leftover Autonomous Balls?
So I haven't really seen this on CD or in the rules but if I have missed it please tell me. So if Robot A,B and C start with balls in autonomous and they miss these shots what happens to these balls since the rules say only one ball per alliance at a time?
Unread 06-01-2014, 20:11
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: Leftover Autonomous Balls?
The balls stay in play, but are not counted if they are scored. If they get stuck in a robot, your alliance will be incapable of scoring until that ball enters a goal.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 06-01-2014, 20:40
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
According to our discussion with a few FIRST staff (including Frank) at kickoff, all of the autonomous balls must be scored BEFORE you can bring new balls in off of the pedestal.
Score all three and then you can start feeding from your HP.
1058 PVC Pirates 2016 - xxxx
Unread 06-01-2014, 20:45
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
I believe the game manual states it this way..
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 06-01-2014, 21:01
Riverdance's Avatar
Riverdance Riverdance is offline
AKA: Beth
FRC #5686 (Wirecats)
Riverdance has much to be proud ofRiverdance has much to be proud ofRiverdance has much to be proud ofRiverdance has much to be proud ofRiverdance has much to be proud ofRiverdance has much to be proud ofRiverdance has much to be proud ofRiverdance has much to be proud ofRiverdance has much to be proud ofRiverdance has much to be proud of
Each robot gets a ball to start autonomous, unless a team chooses to start their robot in the goalie zone. In that case, they can either choose to place their ball on the field where an alliance partner can reach and score it, or they can choose to have their ball removed for the duration of autonomous.
After autonomous ends, the new cycle does not start until all the balls in play during autonomous have been scored, and no assist bonuses can be earned. Once all autonomous balls have been scored, the human player takes a ball from the pedestal, puts it back in play, and the new cycle and collection of assist points can begin!
Unread 07-01-2014, 07:23
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
Rule reference...
G5
For ROBOTS starting in the white ZONE, the TEAM may preload one (1) of their ALLIANCE’s BALLS such that the BALL is touching their ROBOT.
For ROBOTS starting in their GOALIE ZONE the TEAM may decide if the BALL is: staged between the TRUSS and the ZONE LINE and not contacting an ALLIANCE partner, or removed from the FIELD for the MATCH.
If a ROBOT does not report to a MATCH, its ALLIANCE may decide if the BALL is: staged between the TRUSS and the ZONE LINE and not contacting an ALLIANCE partner, or removed from the FIELD for the MATCH.
Violation: If the situation is not corrected before the start of the MATCH, TECHNICAL FOUL per BALL improperly staged.
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 07-01-2014, 09:25
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
It looks like the commencement of cycles for one alliance is independent of the other. That is, when all the red auto-balls have been scored the red cycles begin even if the blue ones are still bouncing around. Since the assist scores for an alliance cannot commence until cycling, the moral seems to be don't place an auto-ball for your robot, unless you're pretty sure you can score it during auto itself or very soon after. The longer an alliance has to get credits for assist scoring the better.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 07-01-2014, 12:30
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Although 3.1.2 is vaguely worded, I think the intent is per alliance rather than all balls. The sentence starts by referring to alliance (singular) & up to 3 balls.
Unread 07-01-2014, 12:38
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
Interesting thought here. I noticed that G5 says "For ROBOTS starting in the white ZONE, the TEAM may preload one (1) of their ALLIANCE’s BALLS such that the BALL is touching their ROBOT." Is this improperly worded, or do you think that this means that you can opt to be in the white zone so you can still get the 5 points but not preload a ball?
EDIT: 5 points for driving to the goalie zone, if that wasn't obvious.
Unread 07-01-2014, 12:54
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
"May" implies that it isn't mandatory, but that might be because I play a bit too much Magic: the Gathering.
Unread 07-01-2014, 14:34
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
I'm still unclear about whether balls left over from autonomous get any points at all if put into a goal at the start of teleop.
The second paragraph of 3.1.4 states that points are awarded once per CYCLE but then table 3-2 distinguishes the base points for a GOAL with the 1-ASSIST point value. Since assists only exist in a CYCLE and there is a minimum of 1 per legal goal, the base point can reasonable be inferred as the point value for a pre-CYCLE ball scored during teleop.
Off to the Q&A...
Unread 07-01-2014, 15:41
Qcom's Avatar
Qcom Qcom is offline
Gearhead
AKA: Quentin
FRC #2996 (Cougars Gone Wired)
Qcom is on a distinguished road
Off to the Q&A...
3.1.2 MATCH Logistics
Although an ALLIANCE may start a MATCH with up to three (3) BALLS, the PEDESTAL will only be illuminated when the last BALL that started the MATCH is SCORED, effectively reducing the number of BALLS in play per ALLIANCE to one (1).
It says in this section (posted earlier by another user) that the balls must be SCORED before another can be added. As it specifies that these balls are SCORED, I think you do in fact get points.
"The systems... They DON'T INTEGRATE!"
Unread 07-01-2014, 07:21
AKA: William Lydick
no team (n/a)
Here's the rule to support you...
With 1370 --
