Go to Post FIRST is not the end...it is the beginning - Greg Needel [more]
Unread 08-01-2014, 21:49
Gibbs's Avatar
Gibbs Gibbs is offline
Just a guy
FRC #2996 (Cougars gone Wired)
Team Role: Mascot
Gibbs is an unknown quantity at this point
Talking Solenoid valve troubles
My team is just getting over our long held fear of Pneumatics, and we seem to be having trouble with the Solenoids specifically the Solenoid valve VUVG-L10-B52-T-m7-1P3-566475. If someone could possibly give us pointers on how to use it, or point us towards a resource for help that would be much appreciated. One of the things we couldn't figure out was which end is the intake, and which end is exhaust. Also our lead programmer says that the solenoid was taking approximately ten seconds to respond to commands.
Thanks!
Unread 08-01-2014, 22:02
Qcom's Avatar
Qcom Qcom is offline
Gearhead
AKA: Quentin
FRC #2996 (Cougars Gone Wired)
Qcom is on a distinguished road
Re: Solenoid valve troubles
Thanks!
Funny, I am having the same issue. I believe the brand name on that model is FESTO.
"The systems... They DON'T INTEGRATE!"
Unread 08-01-2014, 22:26
DonRotolo's Avatar
Back to humble
FRC #0832
Know that these valves need some air pressure to switch.
There is one input, 2 outputs (to the front and rear of the cylinder) and 2 exhausts (which need to remain un-plugged and open).
Regrettably. I don't have the info handy, but just check the manufacturer catalog on their website.
As for the programmer and 10 seconds: Have him "send" the command and watch the lights on the pneumatic solenoid breakout module. If there is any delay it's in his program.
If the delay is between the light lighting and the valve reacting, then it's the valve. But remember these valves need air to switch...
Unread 08-01-2014, 22:38
G Fawkes G Fawkes is offline
FRC #1290
G Fawkes is an unknown quantity at this point
The Festo valve cut sheet I looked at earlier today said they require at least 30 psi supply to operate.
Si Se Puede
Unread 09-01-2014, 03:08
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
Another thing to note, is that if you are using a 24volt solenoid, you must feed 24volts to the pneumatic breakout.
If I remember correctly, the solenoid has one side with three ports and one with two. The two port side is your outputs and the center port on the three port side is the intake, the other two are exhaust.
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 09-01-2014, 17:40
Qcom's Avatar
Gearhead
AKA: Quentin
Yes, we have it hooked up correctly, and double-checked this. I'll run the volt parameters past our electrician.
Unread 09-01-2014, 17:47
AdamHeard's Avatar
Lead Mentor
Probably because you're on the same team.....
Unread 10-01-2014, 19:42
Qcom's Avatar
Gearhead
AKA: Quentin
I know, I realized that later. Sorry!
We got the valves to work. Turns out that we were not allowing the initial pressure to reach 30 psi...
Unread 11-01-2014, 11:05
zsm150's Avatar
zsm150 zsm150 is offline
AKA: Zack Moore
FRC #0314 (Big Moe)
zsm150 is a splendid one to beholdzsm150 is a splendid one to beholdzsm150 is a splendid one to beholdzsm150 is a splendid one to beholdzsm150 is a splendid one to beholdzsm150 is a splendid one to beholdzsm150 is a splendid one to behold
Last year our team use festo valves and they had the worst screw in fittings into the actual valve itself as well as the worst electrical connections. The fittings you had to lock tight the fittings and actually break open the casing and individually solder the wires to the leads. What specific problem are you having?
Unread 11-01-2014, 14:04
DonRotolo's Avatar
Back to humble
FRC #0832
Wow, you actually used Loctite on a pneumaic solenoid valve? Scary.
And you got the type without wires and wonder why you needed to solder them on? Wow again
Neither of those is the valve's fault, though.
Unread 11-01-2014, 18:43
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
http://www.firstchoicebyandymark.com/en/fc14-036
A little safer than loctite
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 11-01-2014, 19:51
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Another thing to remember about pneumatic solenoids is that they are either single-acting or double acting.
A single-acting solenoid has only one solenoid, and has two wires coming out of one side of the solenoid. A double-acting solenoid has two sets of red/black wires, one coming out of each end.
On a single-acting solenoid, if you provide no electricity the input will always be aligned to one specific output. If you provide the necessary voltage to the solenoid it will change to the output output as long as that voltage is held. If you lose power or the solenoid is disabled at the end of the match, the solenoid will always return to the no-power state. This is how some teams have "after the buzzer" mechanisms - when the robot is disabled the solenoid returns to its off state.
A double-acting solenoid will hold its position regardless of the current electrical signal. If electricity to both solenoids is off, the input-output will remain unchanged. If you apply electricity to ONLY the left solenoid, it will push the valve to the right and make output1 active. If you turn off the left solenoid and apply electricity to ONLY the right solenoid, it will push the valve to the left and activate output2. Don't turn on both solenoids valves at once, you will get unpredictable results. Double-acting solenoids are useful for holding a specific position when the robot is disabled.
Art Dutra IV
世上无难事,只怕有心人.
Unread 24-01-2014, 14:35
Daniella Glz Daniella Glz is offline
Daniella Glz is an unknown quantity at this point
Hi All,
My name is Daniella Gonzalez and I am the Product Specialist for Valves for Festo-US. I was reviewing this thread and wanted to make sure everyone knew where to get the proper information on the valves we provided for the 2014 FIRST competition, which are 24V DC double acting VUVG solenoid valves. I have included useful links below. Feel free to either message me or post a reply to this thread if you have any questions regarding either this year's valve offering or one that was provided in the past. I would be more than happy to answer any technical questions you may have regarding our valve products.
http://www.festo.com/cms/en-us_us/9697.htm
http://www.festo.com/cat/en-us_us/da...UVG-G_ENUS.PDF
Unread 11-01-2014, 11:41
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
The valves are called pilot operated valves. While the electrical solenoid initiates the valve to switch states there needs to be a minimum amount of pressure on the valve inlet. Usually around 20 psi. This pressure is what actually makes the valve change position.
Good luck!
2017 Season; Game Announcer at
SBPLI Long Island Regional
