Go to Post Using my Little Orphan Annie Secret Decoder Ring, I have determined that the game hint reads: "Be sure to drink your Ovaltine" - Jill_ls101 [more]
Unread 09-01-2014, 16:51
DweebsUnited DweebsUnited is offline
Head Coder Dude
AKA: Eric Osburn
FRC #2410 (Metal Mustangs)
DweebsUnited is an unknown quantity at this point
Load cell source
Hey all,
As part of our strategy this year we would like to be able to reliably measure the tension in a length of surgical tubing. We know that Bomb Squad was able to do this very successfully using a load cell.
What good sources are there for load cells? We would like to keep the cost reasonable, as most of the units we have found so far are more than 500-600 dollars. Is it even reasonable to find one less that that, or is that a typical price range?
Thanks for any and all help, see you on the fields!
Eric "Ozzy" Osburn
Unread 11-01-2014, 12:22
Head Coder Dude
AKA: Eric Osburn
Re: Load cell source
So after a bit more searching, we got really lucky.
http://www.digikey.com/product-searc...1966743?k=fc23
The FC23xx line of compression sensors linked here is reasonably priced enough to be useful. Keep in mind, to use these you will need an Instrumentation Amplifier to get it to a readable voltage.
The tutorial found here:
http://edg.uchicago.edu/tutorials/load_cell/
explains it pretty simply. Just imagine a cRio instead of an Arduino. It even links to a nice instrumentation amp, also available on digikey!
Good luck to you all! See you on the fields.
Unread 15-01-2014, 23:11
Gdeaver Gdeaver is offline
FRC #1640
Search digi key and you will find a amplified and conditioned version rated at 100lbs.
