Go to Post Injuries can come out of no where. I know this is only a robotics competition but the injury doesnt care where or what you are doing. - nightrenegade00 [more]
Unread 09-01-2014, 20:21
Mr.Trips Mr.Trips is offline
FRC #3179
Mr.Trips is an unknown quantity at this point
Question Problem with FRC Bridge Configuration Utility
Hey, having problems with configuring the D-Link. Yes, Java is installed to latest edition. Yes, wireless settings "Should be Correct". The wireless is off and basically everything is "correct", but I am still receiving this message when I try running the FRC Bridge Configuration Utility,
"An error occurred while initializing the computer network settings;
The application must shut down".
And I can not stress how many different ways I have tried, but I do hope it's a problem that I can give my face a well deserved face palm for missing .
Sincerely,
3179
P.S. I put this in the Labview section because we are using it, and the issue is programming the radio... Please relocate if I placed wrong .
Unread 09-01-2014, 21:11
RyanJK's Avatar
RyanJK RyanJK is offline
Does it come in chrome?
AKA: Ryan Kamphuis
FTC #3758 (Juarez Aztec Eagles)
RyanJK is on a distinguished road
We were having the same problem with the bridge configuration utility. Turns out the issue was due to the fact that we were running the utility on a computer with 64-bit Windows 8.1 as the operating system. When we ran the utility in compatibility mode as Windows 7, it worked like a charm. Hope that helps!
Ryan Kamphuis
Head Mentor, FTC 3758
FRC Game Announcer
Member of the Midwest Regional Planning Committee
2012 - 2015 Chicago, IL Kickoff Coordinator
Alum of FRC Team 2526! Go Crimson Robotics!
Unread 09-01-2014, 21:14
FRC #3179
Re: Problem with FRC Bridge Configuration Utility
We are running Windows 8 too, so ill give it a try on windows 7 then! THANK YOU! Ill report back if it works or not But still thank you.
Sincerely,
3179
Unread 12-01-2014, 14:46
FRC #3179
Well all 3 of our radios are now configured thank you for the help!
Sincerely,
3179
