Go to Post As a team sponsor, we are more concerned with the behavior, attitude and commitment to FIRST ideals than specific performance in the competition. Some of our teams perform well, some struggle, some are in the middle. We support them all in every way we can. - Chris Fultz [more]
Unread 10-01-2014, 09:01
Invictus3593's Avatar
Invictus3593 Invictus3593 is offline
time you like wasting is not wasted
FRC #3593 (Team Invictus)
Invictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really nice
If your imaging tool can't find "FRC_ImagingVersion.ini"
A couple days ago, we went to image our new crio but ran into a problem that other teams may need help on, if they encounter it.
During the image process, the utility threw an error that said it could not locate "FRC_ImagingVersion.ini" in any of the the AppData folders. This was pretty much a universal thing across about 4 different computers, each with all the new software and all the updates. My understanding is that this file tells the computer what image is already on the crio.
The way we solved this is we went to one of the computers that we used last year to image the crio, searched the FRC AppData folder and located the file (it was hiding). After locating the file, we had to copy this file into each of the subfolders in the AppData>frc directory. Only after each subfolder contained this file, did we get through the imaging process successfully.
For teams that encounter this error, this is the annoying, time consuming way to work around it, but we couldn't figure out anything else. Let us know if you encouter the same problem and how you get around it differently!
Happy Building!
Per Audacia Ad Astra
Unread 13-01-2014, 14:32
Bruno#1382's Avatar
Bruno#1382 Bruno#1382 is offline
FRC #1382
Bruno#1382 is an unknown quantity at this point
Re: If your imaging tool can't find "FRC_ImagingVersion.ini"
you can image your cRIO via FTP you open the diretory which the old one is and delete the folders inside than you extract the new image and copy the archives than you paste inside the cRIO diretory
Thanks,Go#1382
