To swerve or not to swerve
What do you guys think about swerve drive in this years game?
Re: To swerve or not to swerve
Swerve is a good option, but if a team doesn't have experience making swerve drives than they shouldn't attempt to make it for the first time during the build season.
If you have built it before and can pull it off then the maneuverability, speed, and power that it offers should be advantageous. I think that swerve is almost always a great choice if you can build it but the question is just if you can build it.
We're not using it, due to lack of resources, but I think that the increased maneuverability will be really helpful for avoiding defense and catching balls.
I think there is no need of a swerve drive because you can have the same movement using a mecanum drive and if you can pull it off you can have a jump drive so you have agility and still been able to push other robots away.
I've always liked 175's clever drive trains. Their 2007 strafing bot was so hard to stop.
To repeat almost everyone above... If you've done swerve before, it's just a matter of justifying the weight of the system. If you haven't done swerve before, design and build one in the off season before using it in a game. Last edited by Ty Tremblay : 10-01-2014 at 13:01. |
#7
I would be tempted to utilize the advantages of 2spd transmissions over a swerve drive given that many robots will have to both play defense and avoid defense, i.e. I want the ability to go faster than anyone who can push me, and push anyone who can go faster than me (assuming I can get a hold of them in high gear).
#8
I see the advantages with a 2 speed being able to our run defense bots and push around others but if you get someone who can operate swerve drive you can practically get out of all sorts of situations as seen with 195 in 2012 and 1717 D'Penguineers... in almost every year recently
#9
I'll be interested to see if some of the top teams that usually run tank drive will choose swerve this year. Some of them have done swerve before, so they could presumably bring it back and still get their other business done. For example: 67, 111, 973, 1114, 1986.
#10
If your team is using swerve, are you using continuous rotation or fixed rotation swerve modules?
#11
Despite constant debate with myself I can't find a better 'bang for buck' than using a 2spd drivetrain. They're light, COTS that won't break the bank, proven, and generally available. Everything you'd want in a drivetrain. |
#12
I doubt you'll see many top teams using a swerve (or mecanum) this year. With a wide-open field, symmetrical game pieces, and many different spots to score from, the additional control and motions you gain from swerve really won't be a significant advantage.
Swerve is a major engineering task, especially for teams who aren't intimately familiar with it (at least one or two successful implementations). The way I see it, you have to be either extremely comfortable with building/programming/maintaining/driving a swerve robot, or you have to be 100% sure that it's going to be a major advantage to have it on your robot. Preferably both. Quote:
Glad to see people from other teams like it and remember it! Swerve is pretty crazy to drive. |
#13
Do you guys think that this is a solid game for one or no?
#14
That's up to you and your team. Do the math, weigh the pros and cons, and maybe even take a vote.
Whether it's swerve, tank, mecanum, or something else, the important part is the engineering. |
#15
We are running it.
No matter what running a swerve drive will always be a hard decision to make just from the resource draw it has. We go really lucky that we have been prototyping it(making modulates and improving on them) for almost a year. We had planed on making it for a off season event but our mill broke down causing us to have all of the peaces to make 6 modules sitting around. After resetting the modules in a new gear box configuration we are set to start machining it, In fact the mill is set to go live tonight. if we were not to have already to have 80% of the stuff to make it we would not even have thought of running it. |
