CRio II will not communicate
Good evening,
We have attempted to image 2 of our CRio II (4 slot) units with the 2014 image (FRC_2014_v52.zip). Initially, we could connect to the CRio II both directly and through the access point. When we used the imaging tool, it found the CRio, we put in our settings, formatting began, and the unit got to the "rebooting state" and got stuck there. After waiting about 10 minutes with no change in the rebooting status, we shut off power to the Crio to start over. Now, we can't even ping the CRio. Our best guess is that the IP address somehow got changed, but we can't find any documentation that gives us a decent guess at what address to ping. (or maybe this isn't the problem). Of course, we decided that something strange happened and repeated the process on another CRio. So, now we have 2 CRios that we can't ping. After 3 hours of effort, we bow to your support. Any suggestions would be appreciated. We think we tried all the troubleshooting documented thus far. We did find that our computer IP was 10.10.24.8 (not 10 or above). We have changed it to .10 now. The AP is 10.10.24.1 and the CRio was 10.10.24.2 (when we could ping it). Again, any help is appreciated. Thanks, AJ & Parker |
Re: CRio II will not communicate
Make sure you have your TCP set to 'use this IP'
and for you it should be '10.10.24.2' If all else fails, NI support will be able to help you out. I just hope you haven't turned your cRIO's into "bricks" |
My team had a similar issue, in which we couldn't update a cRIO, and one of our programmers shut off the power.
What worked for my team was simple: just reset the cRIO using the reset button. After resetting the cRIO, we were able to connect to it and image it like normal using the imaging tool. Hope that helps! |
When you are imaging the cRIO dont connect through the router, just connect straight into the cRIO Ethernet port. Not sure exactly why but the signal that the cRIO rebooted gets lost sometimes with the router. I just had this same issue over the past 2 days
So, until we find a way to restore communication with the CRio, imaging it has been taken off the table ![]() Thanks!! |
One thing we did not try is removing power from the CRio and then holding the reset button as we power up the CRio. Any chance that is what you did to restore communication? Thanks!! |
#7
Also, you should try changing the ip of your computer (just in case you have the same address as the cRIO), and DISABLE ALL OTHER NETWORK ADAPTERS!! If you have wi-fi on, it doesn't usually reconnect. Also, if this doesn't work, go to device manager, go to the settings for your network adapter, and turn off all power saving features. |
#8
Can you confirm that you're following these steps:
http://wpilib.screenstepslive.com/s/...ging-your-crio Brad |
#9
We were unable to download wireshark to search for the device (and this would be our first time using wireshark). So, we decided to ask here first. We will be trying to install wireshark to see if we can find the CRio on another IP address as soon as possible. Thanks!! |
#11
My guess is that your firewall is blocking communication. Are you sure Windows firewall is completely disabled?
#12
![]() Thanks!! |
#13
I am not sure about exactly what happens, but when you reset a crio, doesn't its ip address change? I think you need to change your computer ip to 10.0.0.8 (I chose 8 because nothing uses it) and try to ping 10.0.0.2. (That is a period, not an extra dot.) It would be because the subnet mask on the crio is masking the ip address of the computer, until you change it to have the same initial numbers in the ip address.
#14
Having a similar problem although our cRIO (original model) does not lose communications with the laptop. It simply freezes on the "rebooting cRIO" message, while I can still ping the device or open it with ftp.
The image wipe is not working correctly, because the old robot code is still there along with some image files from last year. Maybe these files are causing problems. I'll try to find some log information tonight. Firewall disabled along with the wlan adapter. I've left it in this state for ~1 hour hoping the avoid a watched pot issue, but no luck. |
