Go to Post Just like any good hardware or software product, "insert foot before putting mouth in gear"..... - dhitchco [more]
Unread 14-01-2014, 21:57
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
RobotBuilder toggle option?
So I'm using RobotBuilder to generate code for a test robot and I want to toggle a command on and off with a joystick button. There is a method in the command-based code to do this (button->ToggleWhenPressed()) but no option in RobotBuilder. (See attached screenshot.)
Any idea why this is? Is there a way to enable this somehow?
Unread 15-01-2014, 10:07
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
Re: RobotBuilder toggle option?
I believe you can simply select "When Pressed" and build the toggle into the command.
Unread 15-01-2014, 10:28
AKA: Brad
#0190 ( Gompei and the Herd)
We might be able to get that enabled in RobotBuilder, but in the mean time, you can edit the whenPressed() method to be toggleWhenPressed() in the generated code. Just be sure to do it outside of the //BEGIN //END generated code comments.
Brad Miller
Robotics Resource Center
Unread 15-01-2014, 18:44
bvisness's Avatar
If you could work that into RobotBuilder I would be incredibly happy. In the meantime, that's exactly what I've done - moved it outside the comments and modified it. Thanks for your help!
