Go to Post The size of your team has nothing to do with the size of your heart. - Amanda Morrison [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 15-01-2014, 13:08
chi-town-biker chi-town-biker is offline
FRC #3135 (Robotic Colonels)
chi-town-biker is an unknown quantity at this point
Closed loop position control in CAN
We’ve used CAN in previous years and like it. This year we plan on using closed loop limit switches and position control. We’re unsure whether to use an encoder or potentiometer based position control. Does anyone have any experience and advice on which to choose? Which is more accurate? Easier to use? Any difference in tuning the PID? Thanks for any help.
Unread 15-01-2014, 13:35
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Re: Closed loop position control in CAN
Since you mention CAN, I assume you are using the PID on the Jaguar.
For position control, we prefer the potentiometer over an encoder mainly since it maintains the home position through power cycles. Depending on your application, the encoder will likely need a limit switch and a power up calibration to find home. We have been successful using a pot tied to the Jaguar running PID in the past - however if the load is asymmetric (think arm working against gravity going up vs. with gravity going down) it is difficult to stabilize with the textbook PID in the Jaguar.
Unread 16-01-2014, 21:00
Thanks. That was very helpful. I didn't realize we'd have to initialize an encoder every time we powered up.
