Go to Post When we stop asking ourselves the hard questions, whether as team leaders or in life, then we are failing. - Al Skierkiewicz [more]
Unread 16-01-2014, 08:19
wildbot3844 wildbot3844 is offline
AKA: James Helton
FRC #3844 (Kentucky Wildbots)
wildbot3844 is an unknown quantity at this point
Pnuematics Programming Issues
Our team has never used pnuematics and we started this year, and we hooked up and wired up everything right according to the manuals, BUT when i try to add the compressor to the program and deploy the code my robot WILL NOT DO ANYTHING,.. does anyone know a solution to this?
Unread 16-01-2014, 09:03
sergioCorral842's Avatar
sergioCorral842 sergioCorral842 is offline
College Student
FRC #0842 (Falcon Robotics)
sergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to behold
Re: Pnuematics Programming Issues
It would help if you can include what language you are using, and post the code you are using.
Team 842 Falcon Robotics: 2011-2015 (President, Head Programmer, Drive Team)
Arizona Regional Winners: 2012-2014 (Thanks 610, 1212, 1726, 3944, 2486, 2403)
Curie Division Semi-Finalists: 2014 (Thanks 1311, 2013, 2928)
Las Vegas Semi-Finalists: 2015 (Thanks 3495, 4415)
Curie Division Quarter-Finalists: 2015 (Thanks 107, 228, 649)
2015 - 2016: Programming, Drive Team, and Strategy Mentor for Team 3187, The Titans
Studying Computer Science- Software Engineering at ASU (Class of 2019)
Unread 16-01-2014, 10:43
AKA: James Helton
i'm using Java and when i deploy this code and my compressor will pulse on when i first enable it then it will just cut off.
public class RobotTemplate extends IterativeRobot {
Compressor compressor = new Compressor(1, 1);
public void robotInit() {
compressor.start();
Unread 16-01-2014, 12:04
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Looks like that portion of your code is without errors.
When the compressor stops running, do you see any error messages printed out to the DriverStation or, if you are connected to your coding computer, in the console?
Are other functions of your robot still operating when the compressor stops running? for example, can you still drive the robot around?
Can you post the rest of the code from your project?
Note, use the [ code ] and [ / code ] tags (without spaces) around a block of code, and it will be easier for people to read.
example:
    compressor.start();
http://team2168.org
Unread 16-01-2014, 15:35
captianjroot captianjroot is offline
FRC #4500
captianjroot is an unknown quantity at this point
Hi, my team is encountering similar problems. We're also using Java, but our code is a little different.
//this is all within our main robot class
    Compressor compress;
    public void robotInit(){
        compress=new Compressor(1,1);
    public void operatorControl() {
        while(isOperatorControl()&&isEnabled()){
            if(!compress.enabled())
                compress.start();
Unread 16-01-2014, 16:44
feverittm's Avatar
feverittm feverittm is offline
FRC #0997 (Spartans)
feverittm will become famous soon enoughfeverittm will become famous soon enough
Originally Posted by captianjroot View Post
                compress.start();
This is of course assuming that the compressor is connected to a spike that is connected to relay channel 1 (on the first digital sidecar if you have more than one) and that the pressure switch is connected to digital input #1 on the same digital sidecar. Also note that you don't really need the 'enabled' clause, you can continually 'start' the compressor. It doesn't hurt anything.
This will only start the compressor in teleop.
Floyd Moore
Mentor Electrical and Pneumatics
Team 997 - Spartan Robotics
Corvallis High School, Corvallis Oregon
Unread 30-01-2014, 12:19
puneeth.meruva puneeth.meruva is offline
MIT Class of 2019
AKA: Puneeth Meruva
FRC #1501 (Team T.H.R.U.S.T)
puneeth.meruva will become famous soon enoughpuneeth.meruva will become famous soon enough
We are having similar problems but the compressor will not turn on at all. We have the same code as the very first presented sample code. Could it be that something is wrong with our sidecar or relay?
Unread 30-01-2014, 13:35
There are several things related to the pressure switch that could keep the compressor from turning on that are not related to the Digital Sidecar or Relay. Is the pressure switch plugged into the port defined in your code? Is the pressure switch wired between signal and ground? Is the Digital Sidecar properly powered (are all 3 power LEDs brightly lit) if you remove the DB-37 cable?
Unread 30-01-2014, 13:46
MIT Class of 2019
AKA: Puneeth Meruva
The led's for power to the sidecar do turn on and I believe that the pressure switch ports are correctly assigned in the code. How exactly is the pressure switch supposed to be wired?
Unread 30-01-2014, 13:50
otherguy's Avatar
sparkE
AKA: James
See response to your question in the other thread:
http://www.chiefdelphi.com/forums/sh...44&postcount=7
http://team2168.org
