Thread Tools |
Rating:
Display Modes |
Can a sledge hammer be used?
Hello, I am part of Robotics class at my school that has two teams going to the FRC competition. One of the teams was wondering if they could use a 10 lb. manufactured sledge hammer to shoot the ball into the goals.
Any information that anyone could provide would be greatly appreciated. Thank you. |
Re: Can a sledge hammer be used?
I don't see a rule prohibiting it, but there are some you have to keep in mind...
•R13 ROBOT elements created before Kickoff are not permitted. ROBOT elements, including software, that are designed before Kickoff are not permitted. Exceptions include the following: A. BUMPERS, B. OPERATOR CONSOLE, C. battery assemblies per R5-A, and D. software and designs with source files publicly available prior to Kickoff. •R3 The ROBOT must satisfy the following size constraints: A. the total length of the FRAME PERIMETER sides may not exceed 112 in. (see Figure 4-1 for examples), B. a ROBOT may not extend more than 20 in. beyond the FRAME PERIMETER (see Figure 4-2 for examples) (see G24), and C. the ROBOT height may not exceed 60 in., except as allowed by G23. D. Any extension above 60 in. may not exceed a 6 in. diameter vertical cylinder (see Figure 4-3 and Figure 4-4 for examples), per G23. Those are the only rules that I can find that would limit anything on your robot. |
KE = 1/2 m (v)squared
Remember that mass is not as important as speed ... |
As Bob Steele hinted, velocity is significantly more important. If your object is moving at 10m/s at weighs 10kg, then your Energy would be (1/2)(10)(10)^2
so, 500. Double the mass; (1/2)(20)(10)^2 1000. Double the velocity; (1/2)(10)(20)^2 2000. Making it twice as heavy makes it hit twice as hard. Making it twice as fast makes it hit four times as hard. If you're considering hitting the ball with an object in order to impel it, you should focus on making your "Hitting Object" faster, not heavier. Last edited by blaze8902 : 18-01-2014 at 18:12. Reason: Clarify. |
•R13
ROBOT elements created before Kickoff are not permitted. ROBOT elements, including software, that are designed before Kickoff are not permitted. [/quote] This can't possible apply to 3rd party manufactured elements. I'm 100% positive those extra Talons you ordered were made before Jan. 4th. Those pistons? Made before Jan. 4th. Wouldn't a sledge hammer fall into the same category as stuff such as this? |
#7
Though I would not recommend using a sledge hammer, I haven't seen anything in the rules that would really keep you from using it besides the fact that you have to be careful that it couldn't accidentally damage another robot. As this isn't battle-bots (sadly) I would be careful what you use. The inspectors could be really picky about that. But I wouldn't rule the option out entirely.
#9
Opportunities for possible frame parameter violation would raise the battle bots concern. I have seen teams attach all kinds of heavy items, however generally for weight management proposes and they were static not actuated.
#10
If they use it in a way that is meant to damage another robot, they'll be penalized appropriately. That is a game play issue and not an inspection issue. The "Battle Bots" concern is not a real thing. |
#11
FIRST is about being creative I'd say go for it but go with caution. Others have stated the frame rules so go for it just be careful. Also have a backup plan just incase you can't use the sledgehammer for whatever reason. Thats just my opinion though
#12
FRC Team 578 used a sledge hammer to kick the ball over the goal in 2008. It was a it or miss proposition. Mostly the robot didn't hold the ball very well so if the bot got jostled the ball would fall off so they would have to go acquire the ball again and drive back around to shoot so it wasn't very efficient.
#13
I've seen a metal working vise and a small anvil used on a robot... so why not a sledge hammer.
Just remember to play some appropriate music when the judges come by. Jason |
#14
See Rule G28:
Got it -- but again, this is a game play violation and there's nothing about the nature of a sledgehammer that makes it more prone to violating this rule, right?
It just struck me as odd advice given the nature of the question. |
