Go to Post Just like a mentor used to call a deburring tool, the whirlygig....it just sticks. Also, whirlygig....what a sweet name for a tool. - Stephen Kowski [more]
Unread 18-01-2014, 15:00
gabrielc97's Avatar
gabrielc97 gabrielc97 is offline
AKA: Gabriel
FRC #4029 (Spartan Bots)
gabrielc97 is an unknown quantity at this point
How many pneumatic pistons can be carried on the chassis?
My team is planning on using pneumatic pistons to control a mechanism, but we were wondering if there was a limit to the amount of pistons that can be carried on the chassis.
any help is appreciated! thanks in advance!
Gabriel
Unread 18-01-2014, 15:07
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
Re: How many pneumatic pistons can be carried on the chassis?
There are no rules that limit the Number of pistons that you may use. However, please observe the burst pressure when selecting pistons.
Your main and limiting factor to the number pistons is the amount of air that you have to work with and the speed that the compressor will be able to deliver the volume of air needed to do the work you are asking.
If you plan on trying to cycle a 3 inch piston with 12 inch stroke, you will run out of air real quick.
Unread 18-01-2014, 15:37
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
I can't take it anymore! They are cylinders not pistons,
This message brought to you by GOMA (grumpy old men of America)
Unread 18-01-2014, 17:48
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Similar question here, the solenoid breakout can control 8 solenoids, is there a way to control more than 8? Secondly can we control two solenoids off of one output on the breakout board?
Unread 18-01-2014, 17:52
You can use a second breakout board. Or, you could use a relay controlled by the sidecar.
Unread 18-01-2014, 17:53
Bob Steele's Avatar
AKA: Bob Steele
You may control solenoids the old fashioned way too.
You may use a spike and control through the digital side car.
They will need to be 12 volt solenoids though...
Unread 18-01-2014, 18:10
dradel's Avatar
Why didn't I think of that?? Seems like the spike would be a cheap way out. Cheaper than a new module an breakout board.
Unread 18-01-2014, 23:03
A spike may also control multiple solenoids, if you are trying to use a few in parallel. R51.
Unread 19-01-2014, 00:16
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Amen!
Also, obligatory "How-about-we-just-read-the-rule-book-instead-of-posting-on-Chief-Delphi" grumble.
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
