Is their a way to stop inventor crashes or delays?
I am just noticing but not sure the use of iparts and passing those iparts to different .ipj files cause the conflicts. The other problem that might add is the assemblies become so large with constraints. Is there a reasonable limit to run these assemblies. Also is Vault better for multiple users to work on assemblies than a single user profile. ![]() |
Re: Inventor help
If your computer is having trouble running inventor it could cause crashes/delays. A couple things to fix this are making sure everything on the view tab is off (shadows, textures, etc.) and also going to performance mode in the hardware tab of the options menu.
Re: Inventor help
Can you give me more information on the following:
1. CPU 2. Memory - RAM 3. Graphics card and memory 4. Version of Inventor |
Re: Inventor help
I know Phil is the man when it comes to Inventor, but the first 2 things I always do are:
Update your video card driver Unload all the "add ins" you can Mr. B |
Re: Inventor help
I've had a lot of similar troubles with Inventor and checking my graphics card updates solved my problem. It could really be this easy.
Re: Inventor help
I agree with the previous comments from Caitlin and Mr. B.
Graphics cards and drivers are typically the issue. Also, check these links. http://usa.autodesk.com/adsk/servlet...018#sect ion4 http://usa.autodesk.com/adsk/servlet...&siteID=123112 |
