Go to Post FIRST is like a big roller coaster, that can only be experianced if one takes a ride which can become a liftime experiance. - activemx [more]
Unread 24-01-2014, 00:08
Lexlukener's Avatar
Lexlukener Lexlukener is offline
Project Manager/Lead Engineer
AKA: Luke Buckner
FRC #4265 (Secret City Wildbots)
Lexlukener is a name known to allLexlukener is a name known to allLexlukener is a name known to allLexlukener is a name known to allLexlukener is a name known to allLexlukener is a name known to all
Super Simple One-Way Winch Mechanism w/ Neutral Shift Option
I am the Co-Engineering lead on Team 4265 Secret City Wildbots, and we recently developed an easy way to develop and manufacture a winching mechanism with the ability to shift into neutral position with the use of VexPro's 2-Stage BallShifters. We simply assembled the ballshifter but on the front outer-plate of the ballshifter we machined a slot just wide enough for a 3/8' ratcheting wrench and removed the gear driving the low gear shifting side and sliped in the ratcheting wrench as seen in the pictures below with a spacer to keep wrench flush and level in the shifter. I hope this helps bunches
ID:	15938  Click image for larger version
ID:	15939  Click image for larger version
Unread 24-01-2014, 00:58
Re: Super Simple One-Way Winch Mechanism w/ Neutral Shift Option
Could you please take some pictures with a camera that can focus?
Unread 24-01-2014, 01:06
GabeHaro GabeHaro is offline
FRC #5052 (RoboLobos)
GabeHaro is an unknown quantity at this point
Would a similar modification work well on an AndyMark Super Shifter (with dog)? We just happen to have one but we are afraid of using it for this purpose because of the force required to disengage. Would it be worth it to invest in a ball shifter (keep in mind we are tight on funds)? Would the AM shifter work with a direct piston or should we use a lever arm like Ri3D? Has anybody tried this? I just don't want to do anything to damage the gearbox.
Unread 24-01-2014, 02:11
wilful's Avatar
wilful wilful is offline
766 Alum & 4212 Mentor
FRC #4212 (TechnoFerrets)
wilful will become famous soon enough
With a large enough piston, you should be able to directly disengage the dog gear, however, I have read this takes at least a 1.5in bore piston. If you can acquire the same size ball shifter gear, and a ball shifter mechanism, you could modify your dog-shifter gearbox into a ball shifter gearbox.
If you have the resources, you might try putting a bevel into the dog gear, see if that helps at all. However, I have not done the math to see if it would work, and suggest anyone who thinks about trying this to make sure that the force on the dog does not force it out of the gear, or cause the gearbox to malfunction in other ways
Wilful
2009-2013 Student, FRC 766
2013-Present College Student and Mentor, FRC 4212
Unread 24-01-2014, 03:10
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
A little hard on the first time OP don't you think?
And that's actually motion blur due to low lighting, not a focus problem. Try a flash or a tripod.
(I love the design, you might want to cut off the wrench so it just sticks out or if you can, drill a hole in it and mount it inside the housing, just don't forget about it and try driving with it next year )
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 24-01-2014, 08:16
pfreivald's Avatar
AKA: Patrick Freivald
Is a ratcheting wrench rated for forces that high? (Of course, "that high" depends on the rest of the design....)
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 24-01-2014, 13:01
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Assuming 2 minicim motors, the wrench is only seeing roughly 7ft-lbs of torque which seems well in the allowable range for a hand wrench.
Mentor 2415
Unread 24-01-2014, 13:25
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Just make sure you use a Snap-On or Craftsman wrench.
Lifetime guarantee in case it breaks. No receipt necessary.
It'll help when traveling to an outside regional where a Sears may be nearby, or a Snap-On truck can roll to your location.
We actually used a universal joint back in 2006, it broke, and then took it to Sears to get it replaced.
Unread 24-01-2014, 13:39
gsesny gsesny is offline
FRC #5804 (Torch 5804)
gsesny is an unknown quantity at this point
Thanks for the update on the ball shifter. That is really awesome and helped me answer some of our questions. We have the same ball shifter and configured it to give us a neutral gear but were stumped on how to attach the ratchet since you need to have the low gear because it directly connects to the cim motors. Does not having the high gear give you enough torque. How much force can your two stage winch pull with in low gear?
Unread 24-01-2014, 14:11
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
I think you mixed up high and low gear in this post. In this situation the low gear (the ratio with the larger reduction) is disabled and they are only using high gear.
Unread 24-01-2014, 16:53
Sorry yes you are correct! Been a long couple of days!
Unread 24-01-2014, 18:18
pfreivald's Avatar
Good deal. There are a lot of ways that this could be used, and not all of them would be nice to that wrench!
Team 1551
I write books, too!
Unread 27-01-2014, 16:40
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
What output shaft are you using? It looks longer than any we've seen for the two stage model and would really like a longer shaft thats at least 2.5" long. Thanks for any help...
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 27-01-2014, 17:00
Aren_Hill's Avatar
Build Nifty Things
They've removed the stock shaft option and inserted a new piece of Hex stock, sorry we do not sell this as a base option
But you can press (possibly requiring some heat) the existing shaft out and do this, just be sure to replicate the internal features of the shaft you remove.
If only I would've known it'd be a winch game.
-Aren
A guy who likes robots.
Unread 28-01-2014, 20:11
RobotDoktor's Avatar
RobotDoktor RobotDoktor is offline
Cat Herder
FRC #4265 (Secret City)
Team Role: CAD
RobotDoktor is just really niceRobotDoktor is just really niceRobotDoktor is just really niceRobotDoktor is just really niceRobotDoktor is just really nice
Apologies for the low quality photos, I'll post better ones when I can. We have since cut down the wrench (a Craftsman by the way), and added a milled retention plate to prevent the wrench from damaging the shifter casing.
