Go to Post You can never have too many backups. - Venkatesh [more]
Unread 24-01-2014, 15:30
anthonygraff24 anthonygraff24 is offline
FRC #2872 (CyberCats)
anthonygraff24 is an unknown quantity at this point
Pneumatics Coding
In Hauppague High School's guide for coding a compressor, it asks for (in the constructor) int pressureSwitchSlot, int pressureSwitchChannel, int compressorRelaySlot, and int compressorRelayChannel. I assume the slots refer to the slots on the sidecar, but I don't know what the Channels refer to. Any help is greatly appreciated!
Unread 24-01-2014, 15:31
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Pneumatics Coding
The slots actually refer to which slot the sidecar is plugged into on the cRIO. You should be able to get away with just using the 2 parameter constructor and putting in the relay channel and dio channel you plugged the switch and spike into on the sidecar, usually 1 and 1 for us.
Compressor compressor = new Compressor(1, 1);
The above code will work as long as your Digital Sidecar is plugged into the first Digital card on the cRIO. If you have a second digital card on the cRIO and are using that one you can use the below code to create your compressor.
Compressor compressor = new Compressor(2, 1, 2, 1);
