Hi,
I have a PIDController with the PIDSource as an encoder and the PIDOutput as a Jaguar. Even though the PIDController->GetError() returns a value of 100 (the encoder distance value - setpoint (this is correct)), the Jaguars do not run automatically to minimize the error. Why is this happening? |
Re: PIDController not manipulating jaguars
What values did you use for P, I, and D? Did you enable the PID Controller?
P = 13, I = 13, D = 13, PID was enabled.
Are there any flashing or solid lights on the Jaguar? is it a black jag or a grey one? Do you notice the same behavior using BDC-COM?
The Jaguar is a grey Jaguar, and the Jaguar just has a solid orange light. I cannot use Set() to manipulate it either.
Are you using CAN or PWM for the Jaguar. If CAN, the gray Jaguars do not have an RS232 to CAN interface and can not be the first Jaguar in a chain. You should check it by using PC with BDC-COM and a serial cable to a black Jaguar and daisy chain CAN to the gray one. You might as well flash the firmware while you have it hooked up.
#7
Posting your code will help us better help you. |
#8
We also get a PID output with a value between 1 and -1, but the Jaguar does not move. The Jaguar is connected to the PWM output port 1.
#include "WPILib.h"
class RobotDemo : public SimpleRobot
RobotDrive myRobot; // robot drive system
Joystick *stick; // only joystick
DriverStationLCD *screen;
Encoder *encoder1;
Jaguar *motor1;
PIDController *PIDmotor1;
public:
RobotDemo():
myRobot(1, 2)//, // these must be initialized in the same order
stick = new Joystick(1);
screen = DriverStationLCD::GetInstance();
encoder1 = new Encoder(13,14);
motor1 = new Jaguar(1);
PIDmotor1 = new PIDController(0.5,0,0,encoder1,motor1);
PIDmotor1->SetContinuous(true);
PIDmotor1->SetOutputRange(-1,1);
PIDmotor1->SetTolerance(3);
myRobot.SetExpiration(0.1);
* Drive left & right motors for 2 seconds then stop
void Autonomous()
myRobot.SetSafetyEnabled(false);
myRobot.Drive(-0.5, 0.0); // drive forwards half speed
Wait(2.0); // for 2 seconds
myRobot.Drive(0.0, 0.0); // stop robot
void OperatorControl()
myRobot.SetSafetyEnabled(true);
encoder1->Start();
PIDmotor1->SetSetpoint(0);
while (IsOperatorControl())
if(stick->GetRawButton(3))
PIDmotor1->SetSetpoint(100);
if(stick->GetRawButton(2))
PIDmotor1->SetSetpoint(-100);
if(stick->GetRawButton(4))
PIDmotor1->Enable();
screen->PrintfLine(DriverStationLCD::kUser_Line1, "Count = %d", encoder1->GetRaw());
screen->PrintfLine(DriverStationLCD::kUser_Line2, "Error = %f", PIDmotor1->GetError());
screen->PrintfLine(DriverStationLCD::kUser_Line3, "Setpoint = %f", PIDmotor1->GetSetpoint());
screen->PrintfLine(DriverStationLCD::kUser_Line4, "Output = %f", PIDmotor1->Get());
//myRobot.ArcadeDrive(stick); // drive with arcade style (use right stick)
screen->UpdateLCD();
Wait(0.005); // wait for a motor update time
* Runs during test mode
void Test() {
START_ROBOT_CLASS(RobotDemo);
#9
Both the Jaguar and the RobotDrive are using PWM 1.
#10
So if we remove the RobotDrive, it will work?
#11
So if we remove the RobotDrive, it will work, because as I understand RobotDrive uses the Jag ports as well?
#12
Put your PID-controlled Jaguar on a PWM port that isn't already being used by other code. It's a one-character change to your code, and a single connector to move from one set of pins to another.
motor1 = new Jaguar(3); |
