Go to Post Inventions are not built using premade parts. People come up with new ideas, from different angles and with renewed enthusiasm. Playing the game is fun, building and designing is inspirational. - Steve W [more]
Unread 25-01-2014, 16:39
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
Get Array From SmartDashboard
I'm trying to get an array of information about the vision targets to send from the SmartDashboard to the cRIO. I absolutely can't figure out how to do this - the documentation seems much too sparse.
I know that when using LabVIEW we could just use a "SD Get Numeric Array" or something like that. Where's the equivalent function in C++ (or how do I work around it for myself?)
Unread 29-01-2014, 07:26
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Get Array From SmartDashboard
Quick question... are you trying to write code that runs in a SmartDashboard custom widget that creates the array of values and sends them to the robot program?
Brad Miller
Robotics Resource Center
Unread 29-01-2014, 11:05
AKA: Brad
Here is some documentation that shows how to retrieve values in an array on the robot that were generated by RoboRealm for doing vision operations.
http://wpilib.screenstepslive.com/s/...with-roborealm
and here is some documentation that shows how you might send values from a Java client program running on the desktop.
http://wpilib.screenstepslive.com/s/...client-pc-side
This desktop example doesn't use arrays, but from the previous example, it might give you enough information to make it work.
Hope this helps.
Brad Miller
Unread 29-01-2014, 11:17
bvisness's Avatar
Thanks for the advice. Since I'm using C++ (which makes arrays a giant headache) I actually ended up using VBScript in RoboRealm to save the array data I wanted into single variables for sending to the robot. Seems to be working fine!
