Go to Post Don'tcha love technology? :p - Cory [more]
Unread 27-01-2014, 06:31
GuyM142's Avatar
GuyM142 GuyM142 is offline
AKA: Guy
FRC #3339 (BumbleBee)
GuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really nice
Bad readings from the maxbotics sonar
We've managed to wire the sonar to the robot and get reading from it with the LV example,
The problem is that the readings are not accurate. (For both digital and analog)
We actually have 2 of them and both of them aren't accurate. (The readings are jumping or gradually rising to what seems random numbers).
We could read right distances once but it went bad again.
What can we do?
2016-2017 - Programming Mentor
Curie Sub-Division Champions with 694, 379 & 1511
2015 - Team Captain & Head of Programming Crew
Carson Sub-Division Champions with 1325, 20 & 1711
First ever Israeli team on Einstein
2014 - Team Captain & Head of Programming Crew
2013 - Head of Programming Crew
2012 - Member of Programming Crew
Unread 27-01-2014, 08:14
Herbblood's Avatar
Herbblood Herbblood is offline
Knowledgeable
AKA: Ally
FRC #3044 (OxBE4)
Herbblood is an unknown quantity at this point
Re: Bad readings from the maxbotics sonar
We had the same problem and found there were some errors, but we took some data to find a number ours 1.242 I think, which would lead the number read to be closer to the actual distance. Some of the problems with the sensor may be that it is being affected by temperature which changes the speed of sound or then "beam" may be picking up other things in the same area.
Off to WPI!
Go OxBE4
Unread 27-01-2014, 11:26
GuyM142's Avatar
AKA: Guy
How did you get to that number?
Unread 27-01-2014, 11:54
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
We found that there is different backscatter in the beam depending on if you're sensing over carpet vs. sensing over linoleum.
Using a narrow-beam sensor or mounting the sensor > 18" form the ground solved the more general backscatter problem for us, mostly.
GitHub
