Go to Post What isn't fun about watching a robot hang tubes? I love watching my team do it! - Michael Corsetto [more]
Unread 28-01-2014, 00:36
ehoyla's Avatar
ehoyla ehoyla is offline
FRC #1311 (Kell Robotics)
ehoyla is a splendid one to beholdehoyla is a splendid one to beholdehoyla is a splendid one to beholdehoyla is a splendid one to beholdehoyla is a splendid one to beholdehoyla is a splendid one to beholdehoyla is a splendid one to behold
375 Key Hub
I was trying to download the 375 key hub of AndyMark, however every time I try to download the step file, it just opens the product in another tab. Does anyone have a fix for this or happen to have the file they could send me??
Unread 28-01-2014, 00:42
Re: 375 Key Hub
Are you trying to right click and Save As? Then drag and drop into your program.
Unread 28-01-2014, 00:45
ehoyla's Avatar
Re: 375 Key Hub
I've tried that, and it doesn't work.
Unread 28-01-2014, 00:50
Re: 375 Key Hub
Email AM, seems the file just isn't there.
Unread 28-01-2014, 00:52
ehoyla's Avatar
Re: 375 Key Hub
I have thanks, just wanted to see if anyone happened to have the file laying around so I didn't have to wait until tomorrow.
Unread 28-01-2014, 01:31
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
Re: 375 Key Hub
Aloha!
From the looks of it, you are trying to down load the step file for the (AM-134a) 375 Key Hub.. I agree the links are both broken..
Have you tried the (AM-0134) Key Hub?
http://www.andymark.com/product-p/am-0134.htm
The CAD file works fine and the general specs listed are the same. Though it does not show the height..
Could work in a pinch.. just extrude a bit if needed...
Good Luck!
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 28-01-2014, 01:38
ehoyla's Avatar
Re: 375 Key Hub
Thanks so much! I had not tried that.
Unread 28-01-2014, 15:10
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Re: 375 Key Hub
Given it is a fairly simple part I tried to download the PDF file and model the part. Unfortunately there is an issue with that file as well.
I did find a PDF this one, but it does not appear to be the 134a version.
http://www.robotshop.com/andymark-375-key-hub.html
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
