Go to Post Einstein 2015 was just a tryout for FIRST's next warehouse forklift operator. - Jay O'Donnell [more]
Unread 28-01-2014, 18:13
afclsn afclsn is offline
Adam Claussen
AKA: Adam Claussen
FRC #4474 (Silver Circuit)
afclsn is an unknown quantity at this point
Half Sidecar PWM Ports Working
This is team 4474, posting during our second FRC season. It seems that the first 4 PWM ports in our sidecar don't respond correctly. Ports 1 and 2 output "forward" to out motor controllers while ports 3 and 4 output "reverse" at all times. Ports 5 through 10 work just fine. We've tried two different sidecars, several different serial cables, and two different cRIOs with the exact same results. The battery voltage was near full when we tested it as well. Help would be greatly appreciated!
Unread 28-01-2014, 18:23
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
Is the sidecar wired to and recieving 12volts from the PDB and are all three voltage lights on it fully illuminated with the DB37 cable disconnected? ( Cable that attaches to the crio)
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 28-01-2014, 23:39
Adam Claussen
AKA: Adam Claussen
Re: Half Sidecar PWM Ports Working
To be honest, we haven't checked this( we hind of forgot about this) but we kind of assumed that this what the issue, since we ran four motor controllers for like 1/2 hour on our drinetrain (mecanums) with this issue, but using the ports that were working.
Thanks for reminding us of this, we will be sure to check it tomorrow since our meeting is now over. Thank you! We will let you how how it goes.
Unread 28-01-2014, 18:28
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Just to help us help you here are some basic questions.
How are you determining that they are outputting reverse/forward all the time?
How are your motors wired?
How did you determine ports 5-10 are working properly?
What speed controllers are you using and are they wired properly?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 29-01-2014, 00:01
Adam Claussen
AKA: Adam Claussen
We determined that they are outputting forward/ reverse by attaching a cim through a victor and then trying the pwm in each port (disabling the bot and changing the code to account for each new port) when in ports 1&2 spin one direction with no driver controls, and there is a solid green light on the victor. Ports 3&4 spin the other way and display a solid red light, and the rest work as expected with driver controls(we were able to successfully run our mecanum drivetrain in the working ports) The morons are wired to the victors following the wiring diagram, and they work in ports 5-10 (which was determined by by using them to control our robot which behaved as expected) and since everything worked as expected and we followed the wiring diagrams I am pretty sure everything is wired correctly. Any thoughts? Thanks for the help.
Unread 29-01-2014, 00:05
Imaginary Friend
AKA: Kevin Li
Team Role: Student
As previously stated I would check to see if the 12 volts is going into the sidecar.
Kevin Li
596 - Sciclones
Unread 29-01-2014, 00:09
Adam Claussen
AKA: Adam Claussen
We will definitely check this tomorrow, as this is a new assembly of the electronics and it very well could be the issue, I just didn't think to check it.
Unread 29-01-2014, 07:34
We had a similar failure but do not expect this to be your exact issue. We started to lose PWM outputs one after another until half the board had no output. We replaced the DSC and checked the bad one only to find a crack. The way the board is laid out, the crack cut the lines to one of the output devices but not the others.
Unread 29-01-2014, 09:02
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
Check to see if they really are getting a forward or reverse signal. Green on the Jags is forward, red is reverse.
Why do I ask? I'm guessing you're using ports 1, 2, 3 and 4 for your drive motors. 3 and 4 are on one side, correct? If so, then everything is working as it "should", just not what you are expecting. (Since on a normal FRC drivetrain, the left side is a mirror image of the right side, and the motors are rotated 180 degrees...) You'll need to change your code to drive motors 3 and 4 inverted, or on the OUTPUT side of the corresponding Jags (The side with M+ and M-), make the motor's red go to M- and the motor's black go to M+.
If that isn't what you're doing... then something very strange is going on indeed.
EDIT: I guess I didn't understand your problem correctly. You're saying that the problem isn't inversion but lack of control?
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
Unread 29-01-2014, 10:20
Adam Claussen
AKA: Adam Claussen
Yes. The problem is that the motors just spin and we have no control of them when we should be able to control them using the joystick. This is only the case for the first four ports too, since we can control them exactly as we like in the rest of the ports. We had our drivetrain running on the other ports because the first four ports will not work. The motor controllers are wired as they should be. It is really strange. We e had problems with the sidecar last year, but then it was just that metal shavings got into the sidecar and shorted it out. This is not the case this year (we opened it and checked). Any ideas, because right now we are stumped. Thanks.
Unread 29-01-2014, 09:46
Adam Claussen
AKA: Adam Claussen
2 digital sidecars did the same thing, including a brand new one from the KOP. We also opened up the digital sidecar and do not see any cracks/debris/etc.
any other ideas?
thanks.
Unread 29-01-2014, 10:59
any other ideas?
Only of the "are you sure it's plugged in?" sort. For example, what revision of the cRIO image is installed?
Unread 29-01-2014, 11:01
Imaginary Friend
AKA: Kevin Li
Team Role: Student
afclsn, Can you take a picture of your side car and electronics layout for us?
Thanks.
Kevin Li
596 - Sciclones
Unread 29-01-2014, 11:49
Thaddeus Maximus
AKA: Thad Hughes
Try making some code that allows you to directly control each output (As a Jaguar... like jag[1].Set(joystick.GetAxis(1)) ). See if the problem is really hardware or just your code not doing what you think it does.
Webpage
Unread 29-01-2014, 14:14
Adam Claussen
AKA: Adam Claussen
Yeah, we did this before we tried it with code for the mecanums, and it had the problems with the simple code.
