Go to Post it should not matter the gender of a person but rather their ability. - vivek16 [more]
Unread 24-06-2002, 00:27
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Ugh...PWM pin vs. Speed Controller
Posted by Eric Reed at 2/7/2001 6:54 PM EST
Coach on team #481, NASA Ames / De Anza High School, from De Anza High School and It could be you!.
Man oh man. We have snapped off a PWM pin inside a speed controller. Any hope of getting it out? Any ideas about preventing this in the future?
Thanks,
Eric Reed
Team 481
#0047 (ChiefDelphi)
Re: Ugh...PWM pin vs. Speed Controller
Posted by Thomas A. Frank at 2/9/2001 5:20 PM EST
Engineer on team #121, The Islanders/Rhode Warrior, from Middletown (RI) High School and Naval Undersea Warfare Center.
In Reply to: Ugh...PWM pin vs. Speed Controller
Posted by Eric Reed on 2/7/2001 6:54 PM EST:
: Man oh man. We have snapped off a PWM pin inside a speed controller. Any hope of getting it out? Any ideas about preventing this in the future?
If there is nothing sticking up above the level of the plastic, you are in tough shape.
What I have done in the past is to very carefully trim away enough of the plastic around the pin to get enough access to pull out the stub with some VERY sharp tweezers.
Or you could send the VICTOR back to Innovation FIRST to have them replace the connector.
In the future, loop the wire back around to the chassis, and attach it to a cable tie anchor, so that if the lead gets yanked, the force is taken up by the cable, not the connector.
For prototypes, I duct tape the cable down to the deck next to the VICTOR...usually after I damage the first one for the year.
Tom Frank
[IMG] code is Off
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
How do you connect the speed controller fans? Iain Electrical 7 31-01-2003 07:05
Speed controller fan replacement Rickertsen2 Electrical 11 16-01-2003 08:46
Speed Controller Limits yaman Technical Discussion 11 15-01-2003 18:40
making speed controller digital CharlieWilken Electrical 4 01-03-2002 20:15
