Go to Post The fact of the matter comes down to this: No matter what you are interested in, you can always encourage others. - Amanda Morrison [more]
Unread 01-02-2014, 14:53
GearTech GearTech is offline
FRC #0108
GearTech is an unknown quantity at this point
C++ Help with driving the robot forward
Hello, we are of team 108. We are having some problems with our robot/code. In the code, we tell the robot to drive using the myRobot.TankDrive() function (We're driving in autonomous. We're not worrying about Teleop yet).
We have the robot using 4 Jaguars to connect to 4 motors. The Jaguars are connected to the Digital Side Car in this way:
Front Left motor: PWM 6
Rear Left motor: PWM 5
Front Right motor: PWM 2
Rear Right motor: PWM 1
#include "WPILib.h"
#include "DriverStationLCD.h"
 * This is a demo program showing the use of the RobotBase class.
 * The SimpleRobot class is the base of a robot application that will automatically call your
 * Autonomous and OperatorControl methods at the right time as controlled by the switches on
 * the driver station or the field controls.
class RobotDemo : public SimpleRobot
	RobotDrive myRobot; // robot drive system
	Jaguar FR, FL, RR, RL;
	Joystick stick; // only joystick
	DriverStationLCD * screen;
	Watchdog Spot;
public:
	RobotDemo():
		FL(6), RL(5), FR(2), RR(1),
		myRobot(FL, RL, FR, RR),	// these must be initialized in the same order
		stick(1)		// as they are declared above.
		Spot.SetEnabled(false);
		screen = DriverStationLCD::GetInstance();
//		myRobot.SetExpiration(0.1);
		myRobot.SetSafetyEnabled(false);
		screen->Printf(DriverStationLCD::kUser_Line2, 1, "It works $@#$@#$@#$@#$@#es!");
		screen->UpdateLCD();
		myRobot.TankDrive(.5, .5);
	 * Drive left & right motors for 2 seconds then stop
	void Autonomous()
		screen->Printf(DriverStationLCD::kUser_Line3, 1, "It works $@#$@#$@#$@#$@#es!");
//		FR.SetSpeed(.5);
//		myRobot.SetSafetyEnabled(false);
//		myRobot.TankDrive(0.5, 0.5);
		Wait(2.0); 				//    for 2 seconds
		Wait(2.0);
		screen->Printf(DriverStationLCD::kUser_Line4, 1, "It works $@#$@#$@#$@#$@#es!");
	 * Runs the motors with arcade steering.
	void OperatorControl()
//		myRobot.SetSafetyEnabled(true);
//		while (IsOperatorControl())
//			myRobot.ArcadeDrive(stick); // drive with arcade style (use right stick)
//			Wait(0.005);				// wait for a motor update time
	 * Runs during test mode
	void Test() {
START_ROBOT_CLASS(RobotDemo);
Using this code the robot will not drive in autonomous.
We added DriverStationLCD objects and methods to debug and test where the code gets its errors. The code goes through autonomous perfectly, just not driving the robot. We want the robot to drive at half speed forward for 2 seconds. Thank you in advanced.
*EDIT*
Also, the jaguars do not have a solid light when the autonomous is enabled. They are continuously blinking while enabled on every setting.
Unread 01-02-2014, 15:41
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
Re: C++ Help with driving the robot forward
Welcome to Chief Delphi!
The Jaguar LEDs blinking yellow indicates that there is no PWM signal. Check your PWM connections and cables. Also, just a suggestion, but you might find it easier to debug drive motor issues in teleop mode than in autonomous mode.
LuNaTeCs - Learning Under Nurturing Adults Teaching Engineering Concepts and Skills - Small and Mighty!
FRC 316 LuNaTeCs - Student (2011-2014), Lead Programmer (2011-2014), Team Captain (2013-2014), Operator (2013), Drive Coach (2014), Mentor (2015-????)
'11 Philly Regional Finalists, '13 Chestnut Hill Finalists, '13 Lenape Champions, '13 Archimedes Division, '14 Chestnut Hill Champions, '14 Lenape Champions
FTC 7071 EngiNerds - Founding Advisor (2013-2014) | FRC 5420 Velocity - Founding Advisor (2015)
Grove City College Class of '18, Electrical/Computer Engineering (B.S.E.E)
Unread 01-02-2014, 22:46
I've always treated that as deep magic that must not be tampered with. Your initializations quite reasonably put the Jaguars before the RobotDrive, but your declarations have the RobotDrive first.
