Go to Post Off-season events aren't just for gameplay, they should also be a training session for new students and rookie teams. - Bill Moore [more]
Unread 02-02-2014, 14:05
ykarkason ykarkason is offline
21st Century Schizoid Man
FRC #3316 (D-Bug)
Team Role: CAD
ykarkason will become famous soon enoughykarkason will become famous soon enough
Electrical Sub-Base
Hello!
We have recently received from First Choice 4 Festo solenoids without their electronics. We were looking for the electric sub-bases for these solenoids (the little black connectors which are mounted in the sides of the solenoids and have the cables to operate it).
We called Festo in Israel and they don't have the regular sub-bases which work only with 24V (part number 566716) but instead those who work with 24V AND 12V (part number 566714).
The only thing that we're not sure about is the fact that they have a current reduction and we don't know how that might affect the solenoids.
Did anybody else encounter this problem? Will the lower current run the solenoids fine?
Thanks a bunch,
Yiftach from Team 3316, D-Bug, Israel.
Unread 03-02-2014, 10:50
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Re: Electrical Sub-Base
The current reduction is a power-saving feature that reduces the power used by the coil once it has been activated. You should have no problem with them in your robot installation. Activation power is listed as 1 watt and then .35 watt to maintain the coil. This has a big effect when there are a hundred solenoids in use at a process control application. In your case the biggest advantage is that you will be able to get the solenoids to work.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 03-02-2014, 23:30
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Thanks Bill!
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
