Go to Post If your robot can't play at least two matches on one battery, your mechanical design and/or driver strategy needs some rethinking. - Al Skierkiewicz [more]
Unread 03-02-2014, 03:05
ferrari77 ferrari77 is offline
FRC #2583
ferrari77 is on a distinguished road
2583's Octocanum Modules
This year 2583 is using Octocanum for the first time ever
4x1.5" inch Colsons geared to 7 fps and 4" Vex mecanum wheels geared to 20.5 fps (around 15 fps forward after loss of top speed from mecanum)
Gears inside the module get the reduction without any belts or tensioning
One CIM per module
4.1 lbs per module without CIM (6.9 with CIM)
Each side of the octocanum is activated by one 1.0625 bore piston pushing in between them, total of two pistons
Traction wheels deploy on the outside to make it impossible to turn for straight driving in autonomous and to prevent being pushed while shooting
All comments and critiques are appreciated
Unread 03-02-2014, 03:08
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: 2583's Octocanum Modules
Holy image size, Batman!
Is that a mounting hole for a CIM I see there in the side?
I'm right 90% of the time, so why worry about the other 3%?
Unread 03-02-2014, 03:21
FRC #2583
yes it is,
a CIM with a 14 T gear mounts to the side there
(fixed the image size)
Unread 03-02-2014, 08:06
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Depending on gear reduction, frame and power (# of motors) you may be able to turn.
Our LogoMotion octanum, with a cim & 775 on each transmission, actually handled quite well in traction mode, even though it was in 'long' orientation with traction wheels on the ends.
Unread 03-02-2014, 09:30
magnets's Avatar
magnets magnets is offline
These are pretty cool. They are also the first cantilevered meccanum wheels I've ever seen (not that there's anything wrong with that).
Unread 03-02-2014, 09:59
Chris is me's Avatar
AKA: Pinecone
Cantilevered octacanum is far from impossible, but you've got to think seriously about how the module is supported and what moments you are putting on the pivot shaft. How is this attaching to the frame?
Unread 03-02-2014, 10:16
FRC #2583
It pivots around the hole at the top of the module and the standoff on the mecanum side is where the piston will push/pull
I have attached a few screenshots of the side rail including two modules to help visualize it
Unread 03-02-2014, 10:32
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is online now
Robotics Engineer
FRC #0319 (Big Bad Bob)
I like your single piston switching method. Do you have a hard stop for the modules so that the piston doesn't take the path of least resistance and kick one module out, leaving the other un-switched?
Unread 03-02-2014, 12:22
FRC #2583
Its hard to see but if you look at the side view, all the way on the outside there are two 1/2 inch holes and right above those there are two small holes next to the vertical line of three holes.
A bolt/standoff through that hole will act as a hard stop for the module
Unread 03-02-2014, 22:07
FRC #2583
Here are some screenshots of the two positions that the hard stops will create when the piston extends/retracts
Unread 03-02-2014, 22:27
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Have you done the math to make sure your modules will actually shift? We are moving to 4 1.5" diameter cylinders because our 4 1 1/16" were having problems. Our setup is different than yours but it seems like you will have a hard time lifting your whole robot.
Unread 03-02-2014, 23:25
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
We've cantilevered mecanum wheels a few times.
Unread 03-02-2014, 23:30
Electronica1's Avatar
Electronica1 Electronica1 is online now
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
2826 did a cantilevered octocanum in 2011, and their design is on frc-designs. One difference I guess is they had the traction wheel geared for speed and had the Mecanum wheel geared to a lower speed for control purposes.
Unread 04-02-2014, 15:30
FRC #2583
I went through the calculations just now and it seems like it may not be able to lift the robot so we're prepared to switch them out to 1.5'' bore.
I can't figure out how all the forces are acting but looking at how the weight is acting through the mecanum wheel straight up and how the module is pushing sideways it seems like it may roll the wheels outward to switch wheels instead of just pushing straight down to raise the wheel. Would this help at all?
If someone could help me draw a FBD and figure that out, i've highlighted where the piston pushes and the rotation points
Unread 04-02-2014, 16:03
Robotics Engineer
Try modeling it as a torques around the pivot point.
For extension:
How much torque would the weight of the robot on the mecanum wheels impart?
vs.
How much torque can the force from the piston impart?
For retraction:
How much torque would the weight of the robot on the traction wheels impart?
vs.
