Go to Post We can't turn off inspiration and recognition, development and learning with a switch. It is an on-going process. If it were not, there would be no need for CD except for 6 weeks out of the year. - JaneYoung [more]
Unread 05-02-2014, 16:56
gerry gerry is offline
FRC #4144
gerry is an unknown quantity at this point
Xbox 360 controls will this work ?
ive been working on my labview xbox 360 controller just wanted to know if this will work
Unread 05-02-2014, 17:01
FRC #4144
Re: Xbox 360 controls will this work ?
here the telop pics
Name:	telop pic 1.png
ID:	16109  Click image for larger version
Name:	telop pic 2.png
Unread 05-02-2014, 17:32
Owen Makin Owen Makin is offline
FRC #1972
Owen Makin is an unknown quantity at this point
I would use a greater than or less comparison sub.vi than for your triggers. Your button code will not work because you have multiple pieces of code sending conflicting information to the robot. If you pressed a button to turn a relay on, other parts of your code will still be telling to be off. You can only have one going on at a time.
Unread 05-02-2014, 17:49
FRC #4144
alright thanks ill make the corrections now
Unread 05-02-2014, 18:49
FRC #4144
hows this and for the xbox control the value for the left trigger is 0 -1 and i couldn't figure how two do that one because every time i deployed it an error message came up
Unread 05-02-2014, 19:25
As Owen mentioned, you should have only one Relay Set instead of the multitude that you've got now.
It needs restructuring along the line of this example where the values you want cascade through your button choices, but the Set happens only once at the end. Each of your Relay Cases gets replaced with a Select and the values you choose in your true and false cases.
Unread 05-02-2014, 19:42
FRC #4144
how did you get the "off" constant
Unread 05-02-2014, 19:45
FRC #4144
never mind i found it
Unread 05-02-2014, 19:46
Just Create->Constant on the input to the Relay Set, then copy and paste the constant wherever else you want to use it.
Unread 05-02-2014, 19:51
FRC #4144
yea i found it i also have a question
what i wanted to do was if button 1 and button 2 are pressed at the same time a certain action happens and if only button one is pushed a different action happens with that code that you pasted says is if button 2 and 3 are pressed then the relay will run forwards and if only button 2 is pressed then it'll run the relay reverse am i correct ? just to make sure i understand this ^.^
Unread 05-02-2014, 20:08
A little different:
  • No button pressed = OFF
  • Button 2 pressed = Reverse (unless Button 3 is pressed at the same time)
  • Button 3 pressed = Forward (it overrides button 2 if it is pressed at the same time)
Part of what it's doing is saying which button wins if there are two commanding different actions.
Unread 05-02-2014, 20:16
FRC #4144
A little different:
what im trying to do is make like a "condition" per say. if button 5 is pressed relay 1 will move forward however if button 2 and button 5 are pressed relay 1 will move reverse
Unread 05-02-2014, 20:41
Just replace your button 5 with my button 2.
and your button 2 with my button 3, and you get exactly what you stated above.
if button 5 2 is pressed relay 1 will move forward however if button 2 3 and button 5 2 are pressed relay 1 will move reverse
