What is considered a catch
Are there any "possession, control" rules ? What if the ball passes over the truss and falls into a waiting "catching bot", but then bounces out. Is this considered a catch?
Re: What is considered a catch
A CATCH occurs when a BALL SCORED over the TRUSS by a ROBOT’S ALLIANCE partner is POSSESSED by that ROBOT before contacting the carpet, the ROBOT which SCORED the TRUSS, or HUMAN PLAYER. The ref needs to see obvious possession before the ball hits the ground, i.e the ball cant just hit your catcher and bounce right out without you "holding" it first. At least that is what i got from it. |
I would most certainly apply the 'grandmother' rule to this. That is to say if your grandmother (or someone unfamiliar with FRC and its detailed rules) wouldn't think a robot caught the ball, then you didn't really catch it.
If the ball lands in/on your robot and bounces out, that's probably not a catch. |
A CATCH occurs when a BALL SCORED over the TRUSS by a ROBOT’S ALLIANCE partner is POSSESSED by that ROBOT before contacting the carpet, the ROBOT which SCORED the TRUSS, or HUMAN PLAYER. You just need to POSSESS the ball. DjScribbles has quoted the places in the manual and QA relevant to the definition of POSSESSION. CATCH != catch as your grandmother may think. |
2 feet down and a football move common to the game?
sorry, couldn't help it. |
I see a few ways to interpret what's in the manual: "carrying" - passes the grandmother check "herding" - if you can repeatedly bump/push the ball before it hits the ground, you deserve a medal "launching" - Very high-risk IMO, relies on ref's non-reversible call/judgement being the same as yours with regards to a mechanism being in motion relative to the robot; you must also hit the ball mid-air with a moving mechanism which doesn't strike me as practical and would likely result in hunting down the ball, costing you and your alliance precious time. While possibly within the letter of the rule, it is not within the spirit or intent of the rule IMO. "trapping" - if you can pin a ball between your robot and a field element mid-air, you deserve a medal, and i think that would also pass the grandmother rule too So, I suppose you're right in a sense: there are a few cases where a by-the-letter interpretation of the rules results in a CATCH the grandmother rule does not. Though IMO one better think long and hard about the practicality and reliability of making a 'non-grandma-approved' CATCH. I suggest following the grandmother rule from a practicality and reliability standpoint. |
#7
If you are a low resource team and were only able to field a moving lunch tray there are other ways to get a CATCH. If you have a spinning paddle on top of your robot designed to hit the ball in the forward direction all you need to do is park under where the ball will land. If the ball hits your paddle and goes forward it would, according to the manual and QA, be considered a CATCH. Grandma wouldn't think so because it is not a catch, but it is still a CATCH. |
#8
![]() Sorry if my original post did not convey that intent ![]() Last edited by JamesCH95 : 07-02-2014 at 10:15. |
#9
There is no reason to bring opinions on practicality and risk into the discussion as each team must weigh that on their own when designing mechanisms within the rules defined. The OP asked a specific question and the response given was correct. Last edited by Josh Fritsch : 07-02-2014 at 10:18. |
#10
Something to keep in mind is that the same "possession" definition that applies to catching a ball coming over the truss also applies to possessing an opponents ball, which is a technical foul.
If you are prepared to argue that deflecting your own ball should count as a catch, you should also be prepared, as a matter of gracious professionalism, to argue that by deflecting your opponents ball you deserve a technical foul. |
#11
I anticipate the "desired location or direction" being called very strictly with regards to catching to prevent a team from spinning a baseball bat over their robot to earn catch points. If a robot has an active mechanism directing the ball towards the next zone/far wall/friendly robot reliably I expect catch points to be awarded. I am comfortable with my interpretation of the rule but it is slightly at odds with the traditional (grandmother's) definition.
My grandmother's opinion of the rules doesn't bother me this year since an "assist" could be: -Robot Red 1 pins ball against wall for a couple of seconds -Every robot ignores the ball for 90 seconds -Robot Red 2 collects it, drives it the length of the field, and scores it -Red robot 1 recieves the ball and throws it the length of the field -Blue robot bumps it back to the original zone ("traditionally considered incomplete or a turnover) -Red robot 2 collects and scores |
#12
Sorry that this may be a little off topic but when a human player catches the ball over the truss, then places the ball in a robot without the ball ever touching the ground, does that alliance receive catch points in that cycle? I apologize if this is already stated in the Q&A or the manual.
#13
) gives the ball to a [different] awaiting robot, assist points are received, along with the toss points.Im not in a place to go scrounging through rules but I recall discussing this elsewhere on CD |
#14
We'll see I guess. |
