Go to Post Give me more tools; I’ll use the ones that are most useful for the job. - Natchez [more]
Unread 07-02-2014, 16:09
NickRobischeau9's Avatar
NickRobischeau9 NickRobischeau9 is offline
FRC #4925
NickRobischeau9 is an unknown quantity at this point
Gripping the Ball
What material is best for gripping the Ball
Unread 07-02-2014, 16:12
Jibri Wright's Avatar
Jibri Wright Jibri Wright is offline
FRC #1781 (Electric Eagles)
Team Role: CAD
Jibri Wright will become famous soon enough
Re: Gripping the Ball
One that grips the ball the best.
You know someone likes something when after doing it a million times, they still marvel at it as if it was the FIRST.
Greatness asks how can I make it better. Genius asks how can I make it different.
Unread 07-02-2014, 16:40
JohnFogarty's Avatar
AKA: @doctorfogarty
We've found that simple Craftsman Rubber toolbox shelf-liner works quite well.
John Fogarty
Unread 07-02-2014, 22:24
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Silicone works well. If you are coating a surface you can also make ridges and such to add even more "grip"
Unread 07-02-2014, 22:59
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
We're using andymark white hi-grip wheels on a roller. Grip pretty good.
Unread 08-02-2014, 00:55
TheMadCADer TheMadCADer is offline
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
Try out whatever rubber wheels you might have (kit wheels, VEX Pro wheels, BaneBots wheels, etc.), one of those should have a good grip. Just grab a bunch and rub them on the ball, see what sticks best.
Unread 09-02-2014, 23:01
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
It depends on what the substrate is. If you are using wheels, you could go with the green banebot wheels or the high traction tread on almost any wheel. However, if you are simply wrapping a tube you could do it with tennis racket hand grip tape from a sports store. We used that in Breakaway and it worked very well.
_____________________________________________
Last words before magic smoke appears: "There, that oughta work!"
2016 Utah Regional- Engineering Inspiration
2016 Utah Regional- Dean's List Semi-Finalist- Ed O'Connor
2016 Utah Regional- Dean's List Semi-Finalist- Emily Ferrari
2016 Utah Regional- 3rd seed
2016 SBPLI Regional- Finalist, 6th seed
2016 SBPLI Regional- Gracious Professionalism Award
Unread 10-02-2014, 09:22
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Banebots green wheels. Cheap, lightweight, comes with a hex bore, and matches purple powder coat nicely too.
GitHub
