Go to Post I wouldn't want to force another me on everyone! - Andy Grady [more]
Unread 07-02-2014, 19:23
J.Rivas26 J.Rivas26 is offline
FRC #3340
J.Rivas26 is an unknown quantity at this point
Pneumatics Help!
This is our first year using pneumatics and we have some questions about the pressure switch. When the psi in the tanks gets to 115 the compressor turns off, so how does it turn back on? Do we need another switch to tell the compressor to turn on when it drops to around 90 psi, or is it a matter programming the pressure switch.
Unread 07-02-2014, 19:28
yash101 yash101 is offline
AKA: null
Re: Pneumatics Help!
The pressure switch automatically turns it off when full and turns it on when empty. You do not need a secondary switch to aid this switch. If your compressor is turning off too early, check to make sure that the pressure cutoff is right and not low. That can typically solve many of these problems. If you still keep having these problems, check the FRC manual's section on how to set up the pneumatics circuit. Use that as a guide for your current pneumatics circuit and fix what you see isn't working properly, or differently affixed. That will get rid of most of your problems!
Unread 07-02-2014, 19:43
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
The pressure switch should be connected to the DIO on the digital sidecar. The pressure switch will open at around 115 psi, and close again at around 95 psi. You need to program the cRIO to turn on the compressor when the switch is closed, and off when it is open.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 07-02-2014, 19:48
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
WPILib makes this real easy.
Compressor compressor = new Compressor(Pressure switch channel, Compressor relay channel);
compressor.start();
Is all you need if you're using Java. C++ should be similar, if not identical.
