Go to Post why does everyone think im so violent? - Kim Masi [more]
Unread 08-02-2014, 21:51
philso philso is offline
FRC #2587
help needed with Spike relay
We observed some strange behaviour with our Spike relays today. I was unable to find any threads describing symptoms similar to what we saw.
With the Spike in the "Off" state, we observed the LED on the Spike was orange and the voltage across the output terminals was 0Vdc.
We energized the Spike with no load connected an observed the LED on the Spike turn green. The voltage on output terminals was about 11Vdc. The input voltage was 12.45Vdc. When we connect an AndyMark 9015 motor to the Spike output terminals, the voltage goes to 0Vdc and the LED turns orange. The M+ terminal is at 0Vdc with respect to the GND terminal. Disconnecting the PWM cable from the Spike does not change anything.
We observed this behaviour with two different Spikes, one removed from a working robot. We swapped the PWM cable even though we seem to be able to control the Spike. One Spike had a 20A breaker. One Spike had a 20A fuse that appeared good.
We checked the wiring and found that the connections from the PD Board are correct and the orientation of the PWM cable is correct.
We did not happen to note the behaviour of the LED's on the DSC.
Does anyone have any ideas on what we may be doing wrong or what to look for?
Thanks.
Phil
Unread 08-02-2014, 21:56
Jared's Avatar
Jared Jared is offline
Re: help needed with Spike relay
It's likely that the DSC isn't powered properly. Try disconnecting everything but the power cable, and make sure that all three leds are on the bottom.
Also, are the indicator lights for the relays on the DSC changing?
Unread 08-02-2014, 22:39
Zmarken Zmarken is offline
FRC #1716 (Redbird Robotics)
Zmarken is an unknown quantity at this point
My team had the same problem a while ago, but figured it out.
If you take a look at the table in the manual, you'll see that the am-0912 can NOT be powered by a spike relay. It's got nothing to do with your wiring or your programming, it's simply that it can't be run off of only 20a current.
The table also specifies motors that can be used with the spike, but they're weaker motors, and thus might not be suitable for what you're doing.
Hope that helps.
Unread 08-02-2014, 23:14
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Zmarken is correct about the rule, but something else is wrong here, because wiring this motor to a Spike with a 20A fuse should work just fine. We re-did our frisbee shooter using this same configuration, and it works fine ("Demonstration Mode" now!)
A Banebots 390 has about the same rpm - but is lower torque...the 395 is a bit faster...still lower torque though. Both can be run from a Spike legally this year.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 08-02-2014, 23:24
FRC #2587
The AM-9015 was connected to a VersaPlanetary gearbox so that may have raised the starting current up to 63A and tripped activated some sort of current limiting device in the Spike.
We also tried connecting the compressor from this years KOP and got the same result.
Does anyone have an internal schematic for the Spike? Does anyone know if the Spike has some sort of PTC or resettable fuse in the Spike?
Unread 08-02-2014, 23:25
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
There's the yellow fuse on the outside of the Spike. That's the first thing to check.
Unread 08-02-2014, 23:27
philso,
The indication is that you might have a loose connection somewhere at the input of the Spike. This could be a bad crimp or a poorly made termination at the PD. You could have a bad breaker in the PD or it could be not fully inserted. Or you may simply have a bad PWM cable such that the return line is shorted to something. When you add the load, the input likely falls to below 5 volts or pulls the control wiring to some "off" state. There is also the possibility that the DSC power has a problem. Always check to see if there are three LEDs brightly lit on the DSC. Then check for correct operation of the LEDs that feed your relay output.
Unread 08-02-2014, 23:34
Were you running the am-0912 with a spike on your frisbee shooter? I just took a look at all the stall currents of the motors given, and it seems if stall current>30A, then it can't be run on a spike.
Unread 08-02-2014, 23:49
Qbot2640's Avatar
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Yes...it's demonstration only - was illegal last year as well, but we had a different configuration for competition - built the current system as pre-season project for new members this fall. It works great, though - in the application it never gets anywhere near stall torque.
Unread 08-02-2014, 23:56
FRC #2587
Thanks for your input, Al.
The input voltage to the Spike did not change as the motor was connected and disconnected. We put the probes on the input terminals of the Spike so any bad connections "upstream" would have been evident.
Only the output voltage changed. We may have to try it with a lower current load in case there is some current limiting device in the Spike.
Swapping the PWM cable for another one did not seem to change things.
I can also try to measure the current running through the Spike using my clamp-on meter.
Unread 10-02-2014, 09:46
philso,
There is no current limit that I am aware of other than the fuse/breaker. It is just two SPDT relays between input and output with the drive circuitry connecting to the coils. The input is opto coupled from the DSC lines. The Spike does not have the internal protection from dirt and other crud so it is possible that both of your Spikes have a serious amount of contaminant. If you have a fuse in place, they sometimes look good but actually have a small crack that opens with current. Try changing with a new one to be sure.
