Thread Tools |
Rating:
Display Modes |
Catapult releasing mechanism
Here is our issue, our catapult needs to be able to lower into the ball collecting position to scoop up the ball, and them we want to be able to, depending on where along the trajectory we want to relase, hold the arm at that angle, until we need to release. Some form of electric or pneumatic clutch would work, but what we need is recommendation on which ones have been tried and how well they work. Any thoughts??
Re: Catapult releasing mechanism
And you want to get it designed, built, and working in a week? That's going to be tough!
There isn't really enough information in your post to make specific recommendations, since we can't see what your catapult looks like. Generally, making something release at a certain position is a tough problem. We avoid it by making all our mechanisms have only two positions, and use pneumatics to move them. In past years we've used a pneumatic release on a winch, it worked so-so. And we've controlled the position of arms using potentiometer feedback and a PID loop in the program, with varying success. Both of these methods took several weeks to get working. |
Wow- you guys are definitely pressed for time then.
You should be able to make every target in this game using one firing solution ie: one type of shot. There is no real need to be able to adjust your shot to shoot from anywhere on the field- trying to do so adds a huge amount of un-needed (IMO) complexity. Instead of being able to make all kinds of shots, focus on doing one shot really well (consistently) which can clear the truss, move the ball down the field and hit the high goal. You will learn very fast where the robot needs to be to make each shot and it eliminates having to engineer a complex system on the robot to calculate trajectories etc. In your situation, I would recommend a spring-loaded catapult. Latex tubing changes in tension and performance over time so use springs for consistency. An arm on a high torque gearmotor to push the catapult into the "cocked" position, engage a latch to hold it there while the cocking arm rotates out of the way, then release the latch when ready. A winch could be used as well that slackens off once cocked to permit firing. The latch could be something as simple as a latch for a chain-link gate (http://www.plumbersurplus.com/images...132-178772.jpg) actuated by a pneumatic cylinder. All that is required to produce a repeatable shot is open/close the latch, rotate loading arm fwd/rev and two limit switches to stop the arm when the catapult reaches its latching position and when the arm is back in its home position. The entire process of loading can be automated in the program so all the driver needs to do is pull a trigger to shoot- the only logic required is: If latch limit switch not triggered > rotate loading arm FWD. If latch limit switch triggered > close latch and rotate loading arm REV If home limit switch triggered > Stop loading arm. When driver pulls trigger > Release latch The driver will quickly learn where the robot needs to be to hit the high goal ie: how far away from the goal- where the trajectory of the ball is flattest to give the greatest tolerance of error. You could also integrate an ultrasonic ranging sensor with a red light/green light system to tell said driver when they are within shooting range. Last edited by fox46 : 10-02-2014 at 10:08. |
If I can make a recommendation, take a look at jvn's bot. they use a ratchet wrench to spin it into position, then just let go and it won't spin back.
#7
A high strength magnet, or even an electromagnet may be a suitable latch for your design.
#8
And it doesn't have to be that powerful if you can figure out a way to use leverage. Think about the trip mechanism on a mouse trap for instance. |
#10
But are you sure that's what the poster had in mind? That cam and linkage would be quite a challenge for an inexperienced team with one week left in the build season. Last edited by Ether : 10-02-2014 at 14:42. |
#11
We were lucky enough to get picked by Aren Hill's (now an engineer at IFI and on JVN's Ri3D team) team in 2008 at the Colorado Regional. So we were familiar with the "choo-choo" cam and decided to use it as we were walking out of the kickoff presentation. Still it is a challenging effort! |
#13
It's precisely because I was familiar with the challenging cam/linkage design of the JVN Build Blitz bot that I asked Michael what bot he was referring to. It didn't seem to fit his description "then just let go".
#15
The wrench is just to handle back-drive. A cam stores the force in surgical tubing. And its a little tricky to build. |
