Supporting 40lbs Arm with Motor?
Hello Everyone,
Our team is looking to put a long rage shooter and acquisition unit on a single arm. Both units will weigh about 20lbs. The torque on the motor will be near 70-80 foot pounds. Can a Mini CIM and a multiple stage gear box hold the arm up via friction in the gear box. If not, is there a method for running the motor with a certain voltage pattern such that it holds the arm and will not pull a sufficient amount of power away from the drive train.(Electric Break) If not, at last resort, does anyone have any suggestions to apply a mechanical break to the motor shaft. Thanks!!!!! |
Re: Supporting 40lbs Arm with Motor?
How is the motor coupled with your arm? 80ft lbs is a lot of internal friction.
Perhaps you can add counterweights, springs or use a screw mechanism to rotate your arm. |
If possible try to counterweight or otherwise balance the arm so the motor is only moving the arm up and down and you are not stalling the motor to hold the arm in position.
Given the numbers from your post this isn't going to be an easy solution, you may wish to look at gas shocks and other more robust methods of accomplishing this. Good luck! Last edited by Phyrxes : 10-02-2014 at 19:13. Reason: clarity |
Why not simply spring load the rear of your shooter so that it takes some of the load off from the motor? Gravity will assist on the way down to acquire, and the spring will assist to get you started back up.
Worm gear drive?
The elastic is a good idea and the simplest. You could also drive the arm with a screw. It will give you your mechanical advantage with out back driving. Use a Love Joy between your screw and gearbox output shaft.
http://www.mcmaster.com/#spider-couplings/=qn2jdu http://www.mcmaster.com/#acme-precis...screws/=qn2k15 |
#7
I'd highly recommend counterbalancing the arm somehow, either with weight or with some form of spring. If you can't, then you could look into a worm gear to hold the arm in position. Weather a multi-stage gearbox can hold it is entirely dependent on the specifics of said gearbox.
#8
we have a similar weight shooter/arm. Ours is counterbalanced with a gas lift spring like the ones used on car hoods. The arm itself is powered by a banebots 256:1 gearbox connected to a 18 tooth Gates pulley driving a Gate belt around a 50 tooth pulley welded to the arm. Works well .
#9
If the arm only rotates one direction, it may be possible to use a ratchet and pawl.
If not +1 on the spring loading. 1" diameter surgical tubing does wonders. |
#10
Some of you may remember Team Driven's Pizza Box from GKC, Razorback and World Champs, the box weighed 40 or so pounds and we had to use a worm gear box and dual miniCIMs with a 32:1 reduction to lift it. This is a very challenging feat to accomplish. You will not be able to do it with all but the toughest of planetaries with a massive reduction. A banebots 256:1 P60 is only rated at 36 (IIRC) foot pounds of torque and you just double that. Worm gear with a substantial reduction is the way to go.
Worm gears can be ordered to be back drive proof, but beware, cast iron gears can (and will) shatter if they take a shock load (like a sudden hit from your arm being rammed). We had to custom make bronze gears to alleviate this fault Last edited by theawesome1730 : 10-02-2014 at 22:28. |
#11
We have a similar system, and are using a 49.4:1 gear box with a mix of pnuematics. We did have problems with friction, but some lithium grease and letting the system wear in helped. |
#12
We have a RS-775 12 attached to a 1:100 reduction and we mounted a sprocket on the end of our winch. There is then a pin that inserts in the teeth/grooves of the sprocket when we want the motor to brake (not back drive). The 775 will also be on brake when the winch lock in engaged. |
#13
Check out the KOP page and Vulcan Springs. Their constant force springs are an easy way to add a counter balance and can significantly reduce the load you need to break.
BTW They respond quickly and even give you free shipping, great company! |
#14
I think he meant you can an stop the movement of an arm or other mechanism by running the motor opposite to the current rotation.
