Go to Post Difficult? Yeah. Extremely difficult? Some parts. Doable? It's been done. - [more]
Unread 10-02-2014, 21:39
LFRobotics's Avatar
LFRobotics LFRobotics is offline
FRC #4623
LFRobotics is on a distinguished road
Talon Issue
I wrote a program for a Talon speed controller and made it exactly like the other motor progrms that I wrote for Jaguars(which worked perfectly) - the only thing I changed was the
SpeedController motor = new Talon(RobotMap.motorPort);
The program works except for the fact that the motor is always spinning - at a slow rate - but still always spinning - I gave the Jaguar the code to see if it was a programming issue and it worked fine - I exchanged motors - every motor did the same thing.
Does anybody have any idea as to what this could be?
ANY help WILL be appreciated - THANKS!
Unread 10-02-2014, 21:50
Re: Talon Issue
Calibrate the Talon. Procedure in the User Manual: http://www.crosstheroadelectronics.c...Manual_1_3.pdf
Unread 11-02-2014, 22:55
LFRobotics's Avatar
FRC #4623
Re: Talon Issue
Okay - it fixed it - THANKS!
