Go to Post Pro: Very easy to build with. Con: HEAVY AS ELEPHANTS - Tetraman [more]
Unread 11-02-2014, 16:59
graham.robots graham.robots is offline
FRC #4024
graham.robots is an unknown quantity at this point
How to use Axis Camera Servos in Java
Hello,
We are having a problem moving the camera servos with the Axis camera. They are plugged into the digital sidecar through PWM cables, and we have the jumpers installed. We have them declared through the Servo class, however, they still aren't moving with both the setAngle() and set() methods. What are we missing?
Thanks,
Team #4024
Unread 11-02-2014, 17:02
Re: How to use Axis Camera Servos in Java
If you remove the DB-37 cable from the digital sidecar, are all 3 power LEDs lit? Are you enabling the robot on the driver station before trying to move the servos?
Unread 11-02-2014, 17:39
FRC #4024
Yes, all three green LEDs are on with the DB-37 pulled. And yes, we are running it with the driver station enabled.
Unread 11-02-2014, 17:52
Can you post your code?
Unread 11-02-2014, 18:11
FRC #4024
//Declaration
Servo cameray = new Servo(7);
//Implementation
if (aButton.get() && !yButton.get())
//Tried both of these
//cameray.set(1);
cameray.setAngle(180);
else
//cameray.set(0);
cameray.setAngle(90);
