Go to Post I was dragged to the first team meeting in September my freshman year and a week later, found myself at Fall Classic. Needless to say, after experiencing the heat of a competition, I was in love. ... Robotics has become far more than just that. I get to do the coolest thing in the world. - Audrey Chu [more]
View Poll Results: So how do you pick up?
Horizontal Rolly Grabber 71 55.04%
Vertical Rolly Grabbers 25 19.38%
Clamp/Pincher 13 10.08%
Other 20 15.50%
Voters: 129. You may not vote on this poll
Unread 12-02-2014, 01:31
Tyler_Kaplan's Avatar
Tyler_Kaplan Tyler_Kaplan is offline
FRC #1678 (The Citrus Circuits)
Tyler_Kaplan is a glorious beacon of lightTyler_Kaplan is a glorious beacon of lightTyler_Kaplan is a glorious beacon of lightTyler_Kaplan is a glorious beacon of lightTyler_Kaplan is a glorious beacon of lightTyler_Kaplan is a glorious beacon of light
How do you grab the ball?
I hope everyone has had a good build so far, and I wish all of the teams good luck as we finish out with the last week. But as we start to focus a lot of energy on driver training, as coach I'd like to get a better idea of how most robots will be grabbing/picking up the ball. I've seen a lot of teams who use a horizontal bar with wheels on top of it, and the only problem I see with this is that it will be a challenge to corral the ball if it is bouncing a lot. So what kind of mechanism are your teams using? Thanks and good luck!
Unread 12-02-2014, 02:09
RohitD's Avatar
RohitD RohitD is offline
Sleep? What is this term?
FRC #2489 (Insomniacs)
RohitD is an unknown quantity at this point
Re: How do you grab the ball?
We're currently running the above mentioned horizontal bar with wheels. Regarding the bouncing, we tested that along with the amount of time it took a ball to stop bouncing and effectively start rolling. We weren't having any huge issues with intake.
2013 Sacramento Regional Winners—Thank you teams 701 and 3189! #greenalliance
Unread 12-02-2014, 09:12
Solive Solive is offline
FRC #1421 (Chaos)
Solive is an unknown quantity at this point
We built a prototype like you described. It worked pretty well. We also built "El Toro". After testing both we prefer El Toro but both will work. Try experimenting with different wheels. Softer rubber will be better.
Unread 12-02-2014, 09:17
Oblarg Oblarg is offline
AKA: Eli Barnett
Overhead PVC roller covered with TheraWrap, driven by a RS550 on a 26:1 gearbox.
Works like a charm.
"The breakfast of champions!"
Unread 12-02-2014, 10:06
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
With our hands......
Unread 12-02-2014, 13:27
Dr.Gusta's Avatar
Dr.Gusta Dr.Gusta is offline
FRC #5107 (The Neurotoxins)
Team Role: CAD
Dr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of light
We use a 1114 2008 style claw.
Unread 14-02-2014, 19:20
'lil robo-girl 'lil robo-girl is offline
None #3218
'lil robo-girl is an unknown quantity at this point
We have what boils down to a handheld vacuum cleaner attached to a huge suction cup on a metal arm. We added a stronger motor to the vacuum so that it can pick up the ball, which it takes a second or so to do. The biggest problem is that the ball has to be pretty exactly lined up for the seal to form, but there's enough flex room for it to mostly line itself up.
Unread 14-02-2014, 21:45
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
We have a horizontal roller intake. While it is horizontal, it isn't like any intake debuted on a robot (Ri3D or otherwise) thus far.
GitHub
