Go to Post Quitting FIRST was so hard that I felt like I needed a 12 steps program to help me through it. - Ken Leung [more]
Unread 24-06-2002, 00:39
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Drill Mounting
Posted by Dan Richards at 2/11/2001 2:58 PM EST
Student on team #550, WCTS Robotics, from Warren County Vo-Tech and WCTS.
It's team 550 again. We're having trouble mounting the drill housings. Any easy way to mount the cut down plastic drill on an aluminum floor?
#0047 (ChiefDelphi)
Re: Drill Mounting
Posted by Matt Leese at 2/11/2001 3:55 PM EST
Other on team #73, Tigerbolt, from Edison Technical HS and Alstom & Fiber Technologies & RIT.
In Reply to: Drill Mounting
Posted by Dan Richards on 2/11/2001 2:58 PM EST:
I'm assuming you cut off the handle of the drill then.
You'll want to build some sort of mounting bracket for
the drill then (if you have someone skilled in sheet
metal this is their time to shine). It can take a
generic U shape sized for the drill and then just but
some sort of strap to hold it down. You can see some
pictures of what we've done on our website below.
Matt
#0047 (ChiefDelphi)
Re: Drill Mounting
Posted by Alan Federman at 2/11/2001 8:52 PM EST
Engineer on team #255, Odyssey, from Foothill HS, San Jose and NASA.
In Reply to: Re: Drill Mounting
Posted by Matt Leese on 2/11/2001 3:55 PM EST:
: I'm assuming you cut off the handle of the drill then.
You can use the drill housing - Sligthly enlarge the screw holes in the case - Then use either dry wall screws into plywood or bolt through to aluminum plate -
1/4 inch or so - you also can reinforce with shims or
pillowblocks cut out of wood, plastic or aluminum.
Good luck.
[IMG] code is Off
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Emergency drill trade/sell Anarkissed General Forum 3 16-02-2003 22:37
drill motor mounting whynot Technical Discussion 3 03-02-2003 08:24
