Go to Post It is not for any other team to say what is beyond a person's or a team's capabilities. That's why they have mentors :-) - preussrobotics [more]
Unread 12-02-2014, 15:20
JohnGilb JohnGilb is offline
Programming Mentor, Drive Mentor
FRC #0488
JohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura about
How to profile?
Are there best practices around profiling java code on the cRIO?
In the past when programming in LabVIEW we took advantage of the built-in profiler to analyze the performance of our code.
Is there something similar that can be done with Java/NetBeans?
Unread 12-02-2014, 15:22
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: How to profile?
You can see the cpu usage on the driver station while running, other than that I don't know of anything.
Unread 12-02-2014, 15:48
Re: How to profile?
...profiling java code on the cRIO...
You can instrument the code and write the results in a large RAM array.
Then examine the array offline.
