Go to Post The strive for the Chairman's award is by far more important than the award. - Pavan Dave [more]
Unread 13-02-2014, 08:52
mrnoble's Avatar
mrnoble mrnoble is online now
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
LED strips exposed: your advice?
Two rookie members of our team took on the task of creating a light show using multiple strips of individually addressable LEDs, such as these:
https://www.adafruit.com/products/306
They intended to mount them to the robot frame with Velcro, but found the weatherproof sheath didn't stick, so they took the lights out of the sheath.
Considering that each light is now essentially a voltage- carrying circuit, would these strips be in violation? I understand you're not official in your opinions, but I value them anyway.
Unread 13-02-2014, 09:03
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: LED strips exposed: your advice?
I would find better velcro. I have those strips and while you think the case is to keep water out, it's really there to keep you from damaging the circuit. Unprotected in a robot workshop I'd judge their life expectancy to be about 2 days. "Oops" is such an ugly word.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 13-02-2014, 09:40
mrnoble,
The LEDs are considered as Custom Circuits and as such must meet all electrical rules including insulation. Without the protective covering, power and data are exposed on both the surface and back side of the circuitry. This potentially provides a current path to robot frame. If the Velcro isn't working, ty-wraps are a great method of securing them in place.
Unread 13-02-2014, 09:48
Team118Joseph's Avatar
Team118Joseph Team118Joseph is offline
The guy that did the lighting
AKA: Joseph Foster
FRC #0118 (Robonauts)
Team118Joseph will become famous soon enoughTeam118Joseph will become famous soon enough
I wouldn't recommend using the strips exposed because they can be easily damaged.
I recommend using the weather proof sleeve and use heat shrink to close the ends of the segments off. It looks nice and things like low temp hot glue and other adhesives stick to heat shrink allot better than the weather proof sleeve.
Unread 13-02-2014, 10:07
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
We regularly use those strips. Leave the enclosure on (if nothing else, it helps protect them a bit), and use zip ties to secure them. We have zip tied them straight to the frame, but I would also recommend something like these to help where you don't have something use to tie them to.
Just be careful to not tie them down too hard - you can crush the relatively fragile PCB.
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
Unread 13-02-2014, 10:55
Oak1477 Oak1477 is offline
FRC #1477
Oak1477 is an unknown quantity at this point
Those are the exact lights we used last year. I would put them back in the sheath and just zip tie them down if possible. They stay pretty safe that way, we even had them on moving parts and we had very few problems.
Unread 20-02-2014, 01:59
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
My team uses aluminum housing to keep our LEDs from being exposed, especially since they're less than a few centimeters from the floor for the underglow. Just rivet the housing onto the frame and slip on the diffuser, and the LEDs are insulated and protected from other robots, debris, and the field carpet.
